TRIANGLE BOREA BR08 Floor Standing Speakers 150W 92dB 40Hz-22kHz White (Pair)
The Triangle Borea BR08 floor-standing speaker, a variation of the iconic Antal, has been the reference model during the design of the Borea range. Elegant and refined, this one is equipped with four drivers and three channels.
By buying this product you get 109 loyalty points
Reference : 16377
1 090,00 €tax incl.
908,33 € tax excl.
Triangle Borea BR08
Floor Standing Speakers 150W 92dB 40Hz-22kHz Walnut (Pair)
Triangle Borea BR08 Enceintes Colonne 150W 92dB 40Hz-22kHz White (La paire)
The Triangle Borea BR08 floor-standing speaker, a variation of the iconic Antal, has been the reference model during the design of the Borea range. Elegant and refined, this one is equipped with four drivers and three channels. It features a new 25mm diameter EFS fabric dome tweeter, as well as a brand new 16cm midrange with a completely redesigned profile, using a cellulose pulp membrane. Finally, two 16cm woofers with glass fiber cone complete the BR08.
Its three-way design allows it to reproduce the entire audible frequency range, without creating interference between the different transducers, giving the BR08 a fine and precise sound reproduction.
This model is perfectly suited for rooms between 20m² and 40m².
Powerful technologies
The BR08 loudspeakers benefit from the technological and acoustic innovations of the Esprit Ez series, including the cabinetry and driver cones.
EFS Tweeter :
The tweeter equipped in the speakers of the Borea range benefits from a new generation system called EFS (Efficient Flow System). This system is based on the combination of a 25mm silk dome known for its neutrality, and a phasing piece, specifically developed to homogenize the diffusion of high frequencies. This system drastically reduces the directivity factor, regardless of where you are listening in the room. The driver's diaphragm is placed inside a horn cone, limiting edge effects for a clear high-frequency sound reproduction. This transducer is powered by a neodymium magnet motor, capable of generating a large magnetic power for a small footprint. It is associated with a heat sink to guarantee a better power handling.
Mid-range speaker in natural cellulose :
The Borea range uses a midrange driver with a 100% natural cellulose pulp membrane that does not undergo any surface treatment. This avoids any coloring of the intermediate frequencies in order to reproduce voices with realism, while offering a characteristic grain of the most beautiful effect. The profile of the membrane has been reworked to increase the rigidity of the speaker and improve its frequency response.
Percussive bass :
Triangle focuses on fast and accurate bass drivers, using a large motorization and placed in a specially optimized cabinet. The result is a punchy and immediate bass that promotes a controlled rhythmic reproduction. The bass transducers integrated here use a glass fiber membrane. This material ensures a high impact force, without impinging on the vocal register and the overall coherence.
DVAS System :
Following extensive research to reduce internal vibrations related to the cabinet, the Borea range of loudspeakers incorporates openwork internal panels made of MDF and EVA foam to stiffen the transducer and cabinet assembly. This process reduces structural vibration while absorbing low frequency vibrations.
This proprietary system, developed by Triangle and named DVAS (Driver Vibration Absorption System), uses a high density EVA foam gasket at the end of each internal bracing, ensuring a perfect contact between the driver and the bracing, thus reducing the vibrations generated by the driver and transferring only a small amount of vibration to the cabinet. This DVAS system ensures a high degree of neutrality and clarity, without sound coloration.
Decoupling :
Each speaker of the Borea range has its own decoupling system. The BR02s are delivered with rubber pads, protecting the underside of your speakers, but also limiting the transmission of vibrations.
Magnetic cover :
All Borea loudspeakers have a magnetic protective cover, leaving no screws or inserts visible.
Product typeFloor standing speakers
Number of speakers4
Number of ways3
Power handling150W
Sensitivity92dB/W/m
Frequency response (+/-3dB)40Hz-22kHz
High-frequency roll-off3500Hz
Low frequency roll-off215Hz
Nominal impedance  (min/max)3 / 8Ω
Recommended room sizeBetween 20m² and 40m²
Dimensions206 x 1020 x 314mm
Unit weight18.85kg
ColorWhite
QuantityPair
ColorWhite
Impedance (Ω)4
Impedance (Ω)3
Impedance (Ω)8
Loudspeaker diameter (mm)N/A
Efficiency / Sensitivity (dB)92.0
Lowest frequency (Hz)40
Highest frequency (Hz)22000
Power (W)150.0
Number of ways3
Number of loudspeakers4
Speaker typePassive
Speaker form factorTower speaker
The Triangle Borea BR08 floor-standing speaker, a variation of the iconic Antal, has been the reference model during the design of the Borea range....
