TRIANGLE BOREA BRA1 Home Theater Effect Speakers 80W 89dB 90Hz-22kHz White (Pair)
By buying this product you get 39 loyalty points
Reference : 16955
390,00 €tax incl.
325,00 € tax excl.
Shipping date: 25-04-2025.
Triangle Borea BRA1
Triangle Borea BRA1 Enceintes d'Effets Home-Cinéma 80W 89dB 90Hz-22kHz (La paire)
The Triangle Borea BRA1 are speakers dedicated to the reproduction of sound effects within a home cinema installation. They have an adjustable filtering system, allowing them to be used in different ways:
  • In vertical 3D effects : In this type of integration, the effects speakers are placed on top of the main speakers. The BRA1s are then oriented upwards and use the principle of sound wave reflection.
  • In horizontal effects : The speakers are placed on the rear and/or side walls using the integrated mounting system. The inclination of the BRA1's front panel allows for a precise and direct targeting of the sound waves towards the listener.
The use of effects speakers in a home theater system allows maximum immersion and ensures great dynamics, while expanding the sound image.
An impressive sound opening
In order to ensure a perfect homogeneity of timbre with the other loudspeakers of the Borea range, the BRA1s use the main technologies. We find a 25mm EFS tweeter with fabric dome and a 16cm natural cellulose pulp diaphragm bass-midrange speaker. It is in particular this last one which allows the BRA1 offering a remarkable sound opening.
Adaptive filtering
The adjustable crossover of the BRA1 offers these speakers a great deal of versatility, allowing them to be used in both scenarios. If the BRA1 is placed on top of the main speakers, the crossover allows for directivity compensation to preserve the full bandwidth. The selection of the crossover mode is done simply by means of a switch placed next to the terminals.
Product typeEffect speakers
Number of ways2
Sensitivity89dB/W/m
Drivers diameterTweeter : Ø25mm
Woofer : Ø16cm
Power handling80W
Frequency response (+3dB)90Hz - 22kHz
Min/Max rated impedance4.5Ω / 8Ω
ColorWhite
Dimensions (L*H*D)206*180*300mm
Weight3.6kg
QuantityPair
ColorWhite
Impedance (Ω)4
Impedance (Ω)8
Efficiency / Sensitivity (dB)89.0
Lowest frequency (Hz)90
Highest frequency (Hz)22000
Power (W)80.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorSatellite speaker
Speaker form factorOther
