ELFIDELITY AXF-100 PRO III Internal USB Power Filter for PC
Perfect product for anyone using a PC or HTPC as a dematerialized source with a USB converter (DAC). Based on components and very high-end connectivity, it will clean the USB port of the noise generated by the switch mode power supply.
Reference : 9056
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 22-09-2026.
Elfidelity AXF-100 PRO III
Elfidelity AXF-100 PRO III Filtre Alimentation USB Interne pour PC
Perfect product for anyone using a PC or HTPC as a dematerialized source with a USB converter (DAC). Based on components and very high-end connectivity, it will clean the USB port of the noise generated by the switch mode power supply while allowing you to inject if you wish "clean" 5V from an external source (Battery, Linear power supply etc...). This product with advanced power management is capable of automatically switching over if, for example, the external power supply no longer supplies the module correctly.
Requires an internal USB connection on a free motherboard.
Product typeInternal USB Power Filter for PC
Max current5A
Max power25W
Automatic power supply switching speed< 5ms
Ripple factor< 1Hz
Japanese capacitors-
Shielded inductorsTDK
RelayTamakisawa (Japan)
InputJack DC 3.4 / 1.4mm
USB Connector1x USB-A 3.0
State LED indicator-
PCB Dimensions90 x 60mm
Weight130g
Package1x USB 2.0 19-pin to 9-pin internal cable
1x USB 3.0 19-pin to 19-pin internal cable
1x USB-A to DC Jack power cable
1x Type A to USB-A power adapter
InputPCI Express
InputJack DC 3.4/1.4mm
OutputNC
Output voltage (V)5.0
Output current (A)5.0
Input voltage (V)N/A
Power SupplyPower supply filter
31 reviews
Belle surprise.
Acheté sur un coup de tête par curiosité il y a 1 an. Je l'installe 1 an plus tard, en me disant pourquoi pas ?
C'est une belle surprise, en plus sur un pc il est facile de switcher d'un port usb à l'autre, me disant que c'était un effet psycho, mais non, le résultat est là. La grande amélioration est dans les noirs, ce qui donne plus de relief et une douceur à la musique. Bravo, à ce prix c'est cadeau et je conseille un bon câble usb / dc pour l'alimenter ou encore si votre budget le permet, une bonne alim.
This review has been posted for ELFIDELITY AXF-100 PRO III Internal USB Power Filter for PC
Bang for the buck
I already had an iFi Audio reclocker, Focusrite DAC with iFi Elite power supplies and Audioquest Diamond cables so I was a bit skeptical about this card. I was terribly wrong! This Elfidelity raised the sound quality on my PC by a big margin: more air, more details, more calmness, more bass and enhanced holographic sound. I'm getting dangerously close to the sound of a 30k Hi-Fi audio system.
Good product
It's probably not the best board of its kind, but definitely worth the money. This board replaced a Matrix board about 10 times more expensive. Clearer sound, more detail, more air.
Klangbild mehr analog
Habe die Karte mit etwas Geduld in meinen Roon Rock Server eingebaut, und war überrascht wie gut der Klang sich über die Zeit verbessern konnte. Die Karte braucht auf jeden Fall eine längere Einspielzeit ( min. 70 Stunden) um jeglicher Art von Spitzigkeit zu verlieren. Danach klingt Sie einfach wunderbar homogen ,entschlackt und erzeugt ein größeren schwärzeren stillen Hintergrund. Klanglich macht Sie nochmals ein großen Schritt nach vorne, wenn man die Karte mit einem externen Linearen Netzteil betreibt. Tolles Produkt
Ottimo risultato
Devo ammettere che non ho fatto un up-grade singolo ma ho lavorato su più punti in un colpo solo ma il risultato è stato strabiliante. Ho un impianto veramente di livello.
Ho unito un alimentatore lineare da 45 ampere a 15 volt per il mi pc audio gaming, entro nel pc con un ripple a massima potenza sui 45 ampere con 5mV.
Ho un convertitore DC ATX che prende energia da questo alimentatore lineare e smista la corrente nelle varie tensioni sempre con un ripple massimo di 5mV sui vari rail. Ecco che il pc è alimentato con 5mV massimi di ripple.
Così grazie ad Audiophonics uso Ian Canada linearpi mkII più il pacco ultracondesnatori di Audiophonics uscendo dal rail dal DC ATX a 12Volt per alimentare a 5 Volt questa stupenda schedina USB.
Uso axf-107-power-filter-pci-express-pci-express-16x- di audiophonics a monte anche della scheda video
Sempre grazie all'alimentatore lineare da 45 ampere uso i 15 volt verso Ian Canada linerpi mkII (di audiophonics) ed il loro pacco di ultracondensatori verso il dac RME adi 2 pro.
Ho un gruppo amplificatore da 20 mila euro e questa scheda usb insieme al resto pronunciato ha alzato il livello di qulità in modo impressionante. Ciò mi ha permesso di tolgiere tutto il "digitale" dalla catenae la fatica di ascolto. Tutto scorre più fluido musicale, rifinito, apmio, trasparente, silenzioso.
Così ho potuto aumentare pure il finetuning nei cavi segnale, usb, potenza e alimentazioni in modo molto importante. 100 e lode per questa schedina.
Perfect product for anyone using a PC or HTPC as a dematerialized source with a USB converter (DAC). Based on components and very high-end...
