ELFIDELITY AXF-100 PRO III Internal USB Power Filter for PC
Perfect product for anyone using a PC or HTPC as a dematerialized source with a USB converter (DAC). Based on components and very high-end connectivity, it will clean the USB port of the noise generated by the switch mode power supply.
Reference : 9056
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 29-04-2025.
Elfidelity AXF-100 PRO III
Elfidelity AXF-100 PRO III Filtre Alimentation USB Interne pour PC
Perfect product for anyone using a PC or HTPC as a dematerialized source with a USB converter (DAC). Based on components and very high-end connectivity, it will clean the USB port of the noise generated by the switch mode power supply while allowing you to inject if you wish "clean" 5V from an external source (Battery, Linear power supply etc...). This product with advanced power management is capable of automatically switching over if, for example, the external power supply no longer supplies the module correctly.
Requires an internal USB connection on a free motherboard.
Product typeInternal USB Power Filter for PC
Max current5A
Max power25W
Automatic power supply switching speed< 5ms
Ripple factor< 1Hz
Japanese capacitors-
Shielded inductorsTDK
RelayTamakisawa (Japan)
InputJack DC 3.4 / 1.4mm
USB Connector1x USB-A 3.0
State LED indicator-
PCB Dimensions90 x 60mm
Weight130g
Package1x USB 2.0 19-pin to 9-pin internal cable
1x USB 3.0 19-pin to 19-pin internal cable
1x USB-A to DC Jack power cable
1x Type A to USB-A power adapter
InputPCI Express
InputJack DC 3.4/1.4mm
OutputNC
Output voltage (V)5.0
Output current (A)5.0
Input voltage (V)N/A
Power SupplyPower supply filter
28 reviews
Klangbild mehr analog
Habe die Karte mit etwas Geduld in meinen Roon Rock Server eingebaut, und war überrascht wie gut der Klang sich über die Zeit verbessern konnte. Die Karte braucht auf jeden Fall eine längere Einspielzeit ( min. 70 Stunden) um jeglicher Art von Spitzigkeit zu verlieren. Danach klingt Sie einfach wunderbar homogen ,entschlackt und erzeugt ein größeren schwärzeren stillen Hintergrund. Klanglich macht Sie nochmals ein großen Schritt nach vorne, wenn man die Karte mit einem externen Linearen Netzteil betreibt. Tolles Produkt
This review has been posted for ELFIDELITY AXF-100 PRO III Internal USB Power Filter for PC
Ottimo risultato
Devo ammettere che non ho fatto un up-grade singolo ma ho lavorato su più punti in un colpo solo ma il risultato è stato strabiliante. Ho un impianto veramente di livello.
Ho unito un alimentatore lineare da 45 ampere a 15 volt per il mi pc audio gaming, entro nel pc con un ripple a massima potenza sui 45 ampere con 5mV.
Ho un convertitore DC ATX che prende energia da questo alimentatore lineare e smista la corrente nelle varie tensioni sempre con un ripple massimo di 5mV sui vari rail. Ecco che il pc è alimentato con 5mV massimi di ripple.
Così grazie ad Audiophonics uso Ian Canada linearpi mkII più il pacco ultracondesnatori di Audiophonics uscendo dal rail dal DC ATX a 12Volt per alimentare a 5 Volt questa stupenda schedina USB.
Uso axf-107-power-filter-pci-express-pci-express-16x- di audiophonics a monte anche della scheda video
Sempre grazie all'alimentatore lineare da 45 ampere uso i 15 volt verso Ian Canada linerpi mkII (di audiophonics) ed il loro pacco di ultracondensatori verso il dac RME adi 2 pro.
Ho un gruppo amplificatore da 20 mila euro e questa scheda usb insieme al resto pronunciato ha alzato il livello di qulità in modo impressionante. Ciò mi ha permesso di tolgiere tutto il "digitale" dalla catenae la fatica di ascolto. Tutto scorre più fluido musicale, rifinito, apmio, trasparente, silenzioso.
Così ho potuto aumentare pure il finetuning nei cavi segnale, usb, potenza e alimentazioni in modo molto importante. 100 e lode per questa schedina.
Great product
I have a dedicated music pc with all Elfidelity filters(ram, fan, hdd/ssd, pcie and usb) and sounds fabulous. The USB card filter is on par with one from another brand that cost 8 times more (blind A-B test with both and no difference in sq). Highly recommend.
Recommended!
For the money this is an excellent product. Simple to install and recogized by windows on reboot.For best results I would recommend complementing the card with an external linear 5V power supply. The Allo - 5V Power Supply for similar money works fine.
Very good
I purchased this based on previous reviews. And I was not wrong, is very good in terms of sound. In package is everything you need, cables and I didn't expect a charger but is there. Even if is a chinese socket with a little skill I adapted it for european socket. A solid product delivers a good signal for my Dac.
Perfect product for anyone using a PC or HTPC as a dematerialized source with a USB converter (DAC). Based on components and very high-end...
