Elfidelity AXF-101 External USB Power Supply Filter for PC
The AXF-101 is the perfect companion for anyone using a PC or HTPC as a dematerialized source with a USB (DAC) converter.
Based on very high-end components and connectivity, it will clean the USB port of the noise generated by the switched-mode power supply while allowing you to inject if desired 5V "clean" from an external source (Battery, Power linear, etc.).
Specifications:
Characteristics :
