TPA3116D2 Amplifier Module Texas Instrument 2x15W PC Tower
Reference : 11569
34,90 €tax incl.
29,08 € tax excl.
Thisamplification modulehas been designed to be housed in PCs dedicated to audio or HTPC.
Based on the architecture </ strong> of the famous brand Texas Instrumentsit exploits a chipTPA3116D2to provide power up to 2 x 15Watt at 4Ω.
Capable of receiving an external signal via 3.5mm Jackor via an internal connector on the PCB, it will adapt to all your needs.
Note: When using your PC's power supply, remove the jumper located behind the 3.5mm jack to avoid mass problems and take full advantage of the sound quality of the card.
Features:/ Strong>
  • Connection of speakers via sockets banana plug gilded 4 mm
  • Signal input via PCB connector or 3.5 mm jack
  • Board supplied assembled and ready to be powered (Molex PC 12V)
  • PCI Slot Cache
  • Setting offset
  • Bananas, screws and cables 3.5mm jack included
Channel Output Power:
  • 15W / 8Ω (10% THD + N)
  • 22W / 4Ω (10% THD + N)
Total Harmonic Distortion Rate:
  • 0.03% to 10W 4Ω
  • 0.1% to 12W 4Ω
Rate of DIntermodulation istorsion (SMPTE):
  • 0.18% to 1W 4Ω
  • Dynamic range:103dB
  • Yield:
  • 88% at 12W / 8Ω
  • 81% at 20W / 4Ω
  • Dimensions:115 x 70 x 30 (L x W x H)
  • Input impedance: 47 k ohms
  • Weight:224g
Channel2 (Stereo)
