PH 2.0mm Female Terminal 7 Channels White (Unit)
This connector is a PH standard solderless terminal connector. The spacing between connectors is 2.0mm. It allows the design of PH 2.0mm cables for easy connections on PCB.
Reference : 18203
0,40 €tax incl.
0,33 € tax excl.
Shipping date: 29-04-2025.
PH 2.0mm Terminal
PH 2.0mm Female Connector 7 Channels White (Unit)
Boîtier PH 2.0mm Femelle 7 Voies Blanc (Unité)
Product typePH 2.0mm connector
StandardPH
Spacing between connectors2.0mm
Number of channelsx7
Number of rows1
Contacts / CablesNot supplied
Max. current2A (24AWG)
Max. Voltage100V
Length cable fixing2.6mm (+/-0.4mm)
Dimensions16*7*4.5mm
ColorWhite
Quantity1x PH 2.0mm female 7-channel connector
ConnecticFemale
Contacts number7
This connector is a PH standard solderless terminal connector. The spacing between connectors is 2.0mm. It allows the design of PH 2.0mm cables for...
