IAN CANADA PH2.0mm Female / Female Cable 40cm (Unit)
This ready-to-use Ian Canada PH 2.0mm female-to-female cable lets you make fast, solid connections between multiple circuits with PH male connectors. Each termination is fitted with a non-breakable plastic housing. The cables on this ribbon cable are not detachable.
Reference : 20527
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 29-04-2025.
IAN CANADA PH2.0mm Female / Female 2 Poles 2 Connectors Cable 40cm (Unit)
Câble PH 2.0mm Femelle / Femelle 2 Pôles 2 Connecteurs : Vue de face
Type of productPH 2.0mm female/female cable
Number of poles2
Pins spacing2.0mm
Length40cm
PackageSold by unit
Length (m)0.4
ConnecticFemale
Contacts number2
IAN CANADA PH 2.0mm Female / Female 2 Poles 2 Connectors Cable 40cm (Unit)
This ready-to-use Ian Canada PH 2.0mm female-to-female cable lets you make fast, solid connections between multiple circuits with PH male...
