PH 2.0mm Ribbon Cable 12 Pole Female / Female Connector 15cm (Unit)
This PH 2.0mm male/male ribbon cable will allow you to make quick connections between two PH 2.0mm female connectors for your DIY projects. This takes advantage of copper conductors to ensure very good signal conductivity.
Reference : 13135
1,00 €tax incl.
0,83 € tax excl.
Shipping date: 24-04-2025.
PH 2.0 ribbon Cable
PH 2.0mm Ribbon Cable 12 Pole Male / Male Connector 15cm (Unit)
Câble PH 2.0mm Connecteur Mâle / Mâle 12 Pôles 15cm (Unité)
The 12 cables composing this product are detachable.
Cable TypeRibbon cable PH 2.0mm Male / Male
Length15cm
Number of pole12 pole
Conductor materialCopper 7 x 0.16mm
Quantity1 - Unit
Length (m)0.15
ConnecticFemale
Contacts number12
This PH 2.0mm male/male ribbon cable will allow you to make quick connections between two PH 2.0mm female connectors for your DIY projects. This...
