PH 2.0mm Ribbon Cable 12 Pole Female / Female Connector 30cm (Unit)
This PH 2.0mm male/male ribbon cable will allow you to make quick connections between two PH 2.0mm female connectors for your DIY projects. This takes advantage of copper conductors to ensure very good signal conductivity.
Reference : 18326
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 24-04-2025.
Câble PH 2.0mm Connecteur Mâle / Mâle 12 Pôles 15cm (Unité)
This PH 2.0mm female / female ribbon cable lets you make quick connections between two PH 2.0mm male connectors for your DIY projects. Copper conductors ensure excellent signal conductivity.
The 12 cables making up this product are detachable.
Cable typePH 2.0mm Female / Female
Number of poles12 poles
Length30cm
Conductor materialCopper 7 x 0.16mm
QuantitySold individually
Length (m)0.3
ConnecticFemale
Contacts number12
This PH 2.0mm male/male ribbon cable will allow you to make quick connections between two PH 2.0mm female connectors for your DIY projects. This...
