PH 2.0mm Female / Female Cable 2 Poles 2 Connectors 20cm (Unit)
This ready-to-use PH 2.0mm female/female cable allows you to make fast, solid connections between several circuits with PH male connectors. Each termination is fitted with a non-detachable plastic housing. The cables on this cable tray are not detachable.
Reference : 19735
0,70 €tax incl.
0,58 € tax excl.
Shipping date: 08-04-2025.
PH Cable 2.0mm Female / Female 2 Poles 2 Connectors 20cm (Unit)
Câble PH : Front view
Type of productPH 2.0mm female/female cable
Number of poles2
Poles spacing2.0mm
Length20cm
PackageSold by unit
Length (m)0.2
ConnecticFemale
Contacts number2
This ready-to-use PH 2.0mm female/female cable allows you to make fast, solid connections between several circuits with PH male connectors. Each...
