PH 2.0mm Female / Female Cable 3 Poles 2 Connectors 20cm (Unit)
This ready-to-use PH 2.0mm female/female cable allows you to make fast, solid connections between several circuits with PH male connectors. Each termination is fitted with a non-detachable plastic housing. The cables on this cable tray are not detachable.
Reference : 19737
0,90 €tax incl.
0,75 € tax excl.
Shipping date: 30-04-2025.
PH Cable 2.0mm Female / Female 3 Poles 2 Connectors 20cm (Unit)
PH 2.0mm 3 pins cable photo
Type of productPH 2.0mm female/female cable
Number of poles3
Pins spacing2.0mm
Length20cm
PackageSold by unit
Length (m)0.2
ConnecticFemale
Contacts number3
This ready-to-use PH 2.0mm female/female cable allows you to make fast, solid connections between several circuits with PH male connectors. Each...
