HIFI 2000 Cover Housing Aluminum GALAXY GX343-383 (Black)
Reference : 4962
20,90 €tax incl.
17,42 € tax excl.
HIFI 2000 343/383
Aluminum cover for Galaxy 343/383 housing 2mm Black
hifi housing cover 2000 343/383
This brushed aluminum cover is specifically designed for housings GALAXY GX343-383 from the same brand. It allows a 100% aluminum housing with an elegant and sober effect that will join aesthetically into your audio system.
His black anodized finish ensures visual consistency between the different parts of your device.
With a thickness of 2mm, this cover is ideal to protect your device from chocs and interferences.
Similarly, slots dedicated to thermal dissipation are judiciously located to prevent internal heat buildup; which helps to increase the life of your DIY assembly.
This product is also available in silver color.
Type of productCover Case for Galaxy 343/383
Dimensions330 x 233mm
Thickness2mm
MaterialAluminum
Weight0.370kg
compatible productsGalaxy 343
Galaxy 383
MaterialAluminium
Internal width330
Internal depth233
Internal height2
Parfait
Parfaite usinabilité de cet aluminium dont j'ignore la nuance. Ne colle pas à la fraise (2 dents !), et pas obligé d'usiner en UGV sous arrosage haute pression... Résultat parfait.
Son épaisseur (2.0mm) impose l'utilisation de vis tête fraisée M3 maximum. 2.5 ou 3mm donneraient un peu plus de possibilités.
This review has been posted for HIFI 2000 Cover Housing Aluminum GALAXY GX343-383 (Black)
