SF12 Connectors 4 Pole Male / Female Lockable Ø6mm
This product consists of a 4-pole male SF12 connector and a 4-pole female socket. These high-quality connectors feature gold-plated contacts for enhanced conductivity and resistance to corrosion and oxidation. Their body is made of chromium-plated brass and incorporates PPS insulation resistant up to a temperature of 260°C.
Reference : 18179
10,90 €tax incl.
9,08 € tax excl.
Shipping date: 29-04-2025.
SF12 Connectors
These connectors are assembled by soldering. The SF12 male connector features a clamping ring to securely hold the cable to the connector, which accepts cable diameters from Ø4mm to Ø6mm (≤ 18AWG/0.78mm²).
The female connector can be integrated into a panel up to 3.5mm thick. Each connector has a coding pin, and locking is easily achieved by pressing. These SF12 connectors are ideal for any DIY audiophile power wiring project, for example.
Product typeSF12 male and female 4-pole connectors
Pole number4
Contact platingGold
Body materialChromium-plated brass
Insulation
Mounting typeTo weld
Max. mounting panel thickness3.5mm
Max. cable diameterØ4mm à Ø6mm
Locking system
Rated current5A
Rated volatge200V AC
Contact resistance5mΩ
Wire size 18AWG / 0.78mm²
ColorSilver
Totales lengthSF12 male connector: Ø18 x 45mm
SF12 female connector: Ø18 x 25mm
Package1x SF12 4-Pole Male / Female Lockable Connectors Ø6mm
Max cable diameter (mm)6.0
ConnecticMale & Female
Contacts number4
ConnectorSF12
This product consists of a 4-pole male SF12 connector and a 4-pole female socket. These high-quality connectors...
