Snap-Fit GX16 Plug 10 Pin Silver Plated Copper 200V 4A Ø7.5mm
This Aviation GX16 type connector offers you the possibility to create cables whose connections will be particularly robust and resistant. They are suitable for all types of mounting.
Reference : 12757
2,90 €tax incl.
2,42 € tax excl.
Shipping date: 29-04-2025.
GX16 Connector
Snap-Fit 10 Pins Copper Silver Plated 200V 4A Ø 7.5mm
Connecteur GX16 10 Pôles
With Silver Copper contacts, this GX16 connector will ensure optimal signal conductivity.
This is the model with 10 poles.
Cotations
Connecteur aviation GX16 cotations
Shell materialZink Alloy with Nickel Plating
Contacts materialSilver plated Copper
Pins number10
Voltage / Current200V 4A
Connection typeTo solder
Operating temperature-20°C +85°C
Acceptable cable diameter⌀7.5mm
LockableBy screwinge
Two parts connector-
ColorSilver
Max cable diameter (mm)7.5
Mounting typeTo weld
ConnecticMale & Female
Contacts number10
ConnectorGX16
bon produit
Très bon connecteur au niveau réalisation et solide
This review has been posted for Snap-Fit GX16 Plug 10 Pin Silver Plated Copper 200V 4A Ø7.5mm
This Aviation GX16 type connector offers you the possibility to create cables whose connections will be particularly robust and resistant. They are...
