7HZ ARTEMIS39 Portable USB DAC
New
The 7Hz Artemis39 is a compact portable DAC, equipped with an ESS ES9039Q2M chip offering rich, detailed sound and supporting high-resolution audio streams up to PCM 32bit 384kHz and DSD256. What's more, this DAC ensures low power consumption, which combined with an 1100mAh battery, provides comfortable autonomy with up to 10 hours of continuous playback.
Reference : 20719
149,00 €tax incl.
124,17 € tax excl.
7Hz Artemis39 Portable USB DAC ES9039Q2M Bluetooth 32bit 384kHz DSD256
Photo of the 7Hz Artemis39
The Artemis39 features a USB-C audio input and dual output with single-ended 3.5mm jack delivering up to 320mW into 32Ω and balanced 4.4mm jack delivering up to 405mW into 32Ω. This output power is delivered by a high-performance ES9603Q amplifier chip.
This connectivity is complemented by Bluetooth via a QCC5125N chip, enabling wireless streaming of music to the Artemis39 and thus reducing cable clutter. The high-definition Bluetooth codecs aptX, aptX LL, aptX HD and LDAC are supported, for quality listening even when wireless.
The 7Hz Artemis also has a built-in microphone, so you can answer calls quickly and easily. Ideal for use on the move.
Technical characteristics
Product typePortable DAC
InputsUSB-C
Bluetooth
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
DAC ChipES9038Q2M
Amplification chipES9603Q
USB InterfaceSA9137L
Bluetooth chipQCC5125N
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
DSD up to DSD256
Built-in microphoneYes
Battery capacity1100mAh
Built-in DAC filtersx8
SNR129dB (wired)
THD+N0.0002% (wired)
Power outputJack 3.5mm: 2x 320mW @ 32Ω
Jack 4.4mm: 2x 405mW @ 32Ω
Dimensions78 x 39 x 14mm
Weight63g
Body materialMetal
Package1x 7Hz Artemis39
1x USB-C cable
7HZ ARTEMIS39 Portable USB DAC ES9039Q2M Bluetooth 32bit 384kHz DSD256
The 7Hz Artemis39 is a compact portable DAC, equipped with an ESS ES9039Q2M chip offering rich, detailed sound and supporting high-resolution audio...
