AUNE YUKI Portable Balanced DAC Discrete Headphone Amplifier
With the YUKI, Aune unveils a balanced portable DAC featuring a discrete component headphone amplifier stage. This portable DAC incorporates quality components such as two CS43198 DAC chips and no fewer than 16 transistors (4x4) for the amplification stage.
Reference : 18617
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 29-04-2025.
AUNE YUKIPortable Balanced DAC / Discrete Headphone Amplifier 2x CS43198 32bit 768kHz DSD256
Photo of AUNE YUKI
With the YUKI, Aune unveils a balanced portable DAC featuring a discrete component headphone amplifier stage. This portable DAC incorporates quality components such as two CS43198 DAC chips and no fewer than 16 transistors (4x4) for the amplification stage. The YUKI's double-layer structure totally isolates the analog amplification circuit from the digital DAC, delivering high-fidelity musical reproduction. Here are the main highlights of Aune's YUKI:
  • Two CS43198 DAC chips
  • Support for high-resolution PCM 32bit 768kHz streams and native DSD up to DSD256
  • Discrete component headphone amplification (4x4 transistors)
  • USB-C input (UAC 1.0 compatible)
  • 3.5mm jack output (90mW @ 30 Ohm) and 4.4mm balanced jack output (160mW @ 30 Ohm)
The Aune YUKI portable DAC is the perfect partner for your smartphone, tablet or laptop.
AUNE YUKI highlights
Aune YUKI: two CS43198 DAC chips
The YUKI is equipped with two CS43198 DAC chips that independently process the signal of each channel for a clear, rich final audio output.
Photo of DAC CS43198 chips
Photo of AUNE YUKI
Aune YUKI: headphone amplification with discrete components
The Yuki uses a special two-layer printed circuit board to separate the digital input stage from the analog amplification stage. The amplification stage is made up of 4x4 transistors and several independently powered ±5V chips.
Aune YUKI: qualitative performance measurements
The structure of this portable DAC enables it to achieve a THD+N of just 0.00033% and a noise level of just 2.9μV.
The structure of AUNE YUKI
Aune YUKI: compatibility with most headphones and earphones on the market
The Aune YUKI will pair easily with most headphones on the market thanks to its output power, 90mW under 30 Ohm on its 3.5mm jack output and 160mW under 30 Ohm on its Jack 4.4mm balanced output.
Photo of IEMs connected to the AUNE YUKI
Product typePortable DAC
DAC chip2x CS43198
InputUSB-C
Outputs1x 3.5mm jack
1x 4.4mm balanced jack
Supported sample ratesPCM 32bit 768kHz, native DSD up to DSD256
3.5MM HEADPHONE OUTPUT
Output level2Vrms
Noise floor2.6uV
THD+N0.00036%
Output power90mW @ 30 Ohm
BALANCED 4.4MM HEADPHONE OUTPUT
Output level4Vrms
Noise floor2.9uV
THD+N0.00033%
Output power160mW @ 30 Ohm
Dimensions24 x 53.5 x 13mm
ColorSilver
Package1x Aune YUKI portable dac
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43198
Max sampling rateDSD256
Max sampling rate768kHz
ColorSilver
ClassN/A
AUNE YUKI Portable Balanced DAC Discrete Headphone Amplifier 2x CS43198 32bit 768kHz DSD256
With the YUKI, Aune unveils a balanced portable DAC featuring a discrete component headphone amplifier stage. This portable DAC incorporates...
