DD TC35B 2021 Male USB-C to Female Jack 3.5mm DAC Adapter CTIA 32bit 384kHz
This TC35B 2021 adapter consists of a 3.5mm jack female connector on one side and a USB-C male connector on the other side. It will allow you to connect a 3.5mm jack to a device with a USB-C connection only, as it is the case on many recent smartphones.
4.3 / 5
Reference : 15417
39,90 €tax incl.
33,25 € tax excl.
TC35B 2021
TC35B Adaptateur DAC USB-C Mâle vers Jack 3.5mm Femelle CTIA 32bit 384kHz
This TC35B adapter consists of a 3.5mm jack female connector on one side and a USB-C male connector on the other side. It will allow you to connect a 3.5mm jack to a device with a USB-C connection only, as it is the case on many recent smartphones. The components are integrated in a compact and robust 316 stainless steel housing. The TC35B automatically detects and activates when a headset is connected. The adapter is also CTIA compatible and can therefore be used with headsets/earphones with integrated controls and microphone.
In this 2021 version, the TC35B becomes lighter and benefits from a better finish, thanks to the use of a new Aluminium alloy.
Volume control for Apple headphones is not supported.
Product typeJack 3.5mm / USB-C adapter
ConnectorsFemale Jack 3.5mm
Male USB-C
USB CodecALC5686
THD+N< -92dB
DNR> 110dB
SNR> 120dB
Output power30mW @ 32Ω
Recommended headphone impedance16-200Ω
CTIA Support
Housing materialAluminum alloy
Dimensions18.8 x 11.4 x 10.4mm
Weight3.6g
ColorBlue
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate384kHz
ColorBlue
3 reviews
Très bien
Pour mon Raspberry Pi zero 2W je voulais un DAC usb qui ne soit pas énorme et c'est parfait.
J'ai juste ajouter un petit adaptateur micro usb male/usb-c femelle pour faire le job.
Seul petit bémol la puissance de sortie audio est un petit peu faible mais je peux compenser largement avec mon ampli.
La qualité audio est aussi bonne que celle de mon DAC Sabre SA9023.
This review has been posted for DD TC35B 2021 Male USB-C to Female Jack 3.5mm DAC Adapter CTIA 32bit 384kHz
Problème de blindage ?
Fonctionne normalement, pas encore testé en Hi Res.
En revanche, très fort grésillement dans le train (TGV) ... un problème de blindage ?
Fais son job
Utilisé avec "USB payer pro" et fais bien son job, pour le prix je pense qu'il n'y ai pas mieux
This TC35B 2021 adapter consists of a 3.5mm jack female connector on one side and a USB-C male connector on the other side. It will allow you to...
