DD TC35C DAC AL5686 Male USB-C to Female Jack 3.5mm 32bit 384kHz
This TC35C DD adapter for smartphone is composed of a male USB-C connector and a female 3.5mm jack. It also includes a Realtek AL5686 DAC for efficient conversion of the audio signal for a clear and precise reproduction.
4.5 / 5
Reference : 16995
47,90 €tax incl.
39,92 € tax excl.
DD TC35C
Adapter DAC AL5686 Male USB-C to Female Jack 3.5mm 32bit 384kHz
DD TC35C Adaptateur DAC AL5686 USB-C Mâle vers Jack 3.5mm Femelle 32bit 384kHz
This TC35C DD adapter for smartphone is composed of a male USB-C connector and a female 3.5mm jack. It also includes a Realtek AL5686 DAC for efficient conversion of the audio signal for a clear and precise reproduction, while supporting high resolution streams, up to PCM 32bit 384kHz. The robust connector body is made of CNC machined aluminum. Its practical "T" shape allows for a compact design.
Be sure to plug in the headphones before connecting the DAC to the device.
Product typeAdapter and DAC
Connectors1x Male USB-C
1x Female Jack 3.5mm
DAC ChipRealtek AL5686
Output power30mW @ 32Ω
Dynamic range> 110dB
THD+N< -92dB
SNR> 120dB
Dimensions16.6 x 16.2 x 9.6mm
Weight3.5g
OutputJack 3.5mm
DAC / ADC ChipAL5686
Max sampling rate384kHz
ColorSilver
2 reviews
DAC compact
DAC compact, très pratique.
DAC utilisé pour brancher des écouteurs, un casque et des enceintes sur un téléphone portable.
Très bonne qualité sonore.
Des grésillements de temps en temps lorsque j'utilise des écouteurs, certainement un problème de compatibilité.
This review has been posted for DD TC35C DAC AL5686 Male USB-C to Female Jack 3.5mm 32bit 384kHz
excellent
pour le prix le son est tres bon tres ample et ne craque pas à fort volume et reconnu toute suite par mon smartphonr (samsung s9+).
This TC35C DD adapter for smartphone is composed of a male USB-C connector and a female 3.5mm jack. It also includes a Realtek...
