DD TC35CM2 Adapter DAC Headphone Amplifier
The TC35CM2 DDHiFi adapter features an independent DAC chip and ES9603Q amplifier chip. Its DAC chip supports sampling rates up to PCM 32bit 384kHz, while its ES9603Q amplifier chip delivers up to 45mW+45mW @ 32 ohm with a THD+N of less than 1%.
Reference : 19792
35,90 €tax incl.
29,92 € tax excl.
Shipping date: 24-04-2025.
DD TC35CM2 Adapter DAC Headphone amplifier USB-C to Jack 3.5mm Female 32bit 384kHz
Photo of DDHiFi TC35CM2 adapter
The TC35CM2 DDHiFi adapter features an independent DAC chip and ES9603Q amplifier chip. Its DAC chip supports sampling rates up to PCM 32bit 384kHz, while its ES9603Q amplifier chip delivers up to 2x45mW into 32 ohm with a THD+N of less than 1%. In addition, the female jack socket is compatible with 4-pin CTIA jacks if you wish to use earphones with a microphone for receiving and making calls. Another advantage is the cable linking the two connectors, which features OFC copper conductors for optimum conductivity.
Product typeAdapter / Portable DAC / Headphone amplifier
Amplification chipES9603Q
Connectors1x USB-C
1x 3.5mm female jack (4-pin CTIA compatible)
Frequency response20Hz-20kHz
Supported sample ratesUp to PCM 32bit 384kHz
Output power45mW+45mW @ 32 ohm (THD+N<1%)
SNR≥ 112dB (32 ohm load, A-WT)
Dynamic range> 120dB
THD< 0.008% (32ohm load)
Noise level< 3uV (A-wt)
Cable conductor materialOFC copper
Cable length9cm
Weight9.5g
ColorSilver
Package1x DD TC35CM2
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate384kHz
ColorSilver
DD TC35CM2 Adapter DAC Headphone Amplifier USB-C to Jack 3.5mm Female 32bit 384kHz
The TC35CM2 DDHiFi adapter features an independent DAC chip and ES9603Q amplifier chip. Its DAC chip supports sampling rates up to PCM 32bit...
