DD TC35i 2022 DAC C101 Male Lightning to Female Jack 3.5mm CTIA 24bit 48kHz
This DD TC35i 2022 smartphone adapter consists of a male Lightning connector and a female 3.5mm jack. It embeds a C101 DAC allowing an efficient conversion of the audio signal for an accurate sound reproduction.
Reference : 15931
49,90 €tax incl.
41,58 € tax excl.
DD TC35i 2022
Adapter DAC C101 Male Lightning to Female Jack 3.5mm CTIA 24bit 48kHz
DD TC35i 2022 Adaptateur DAC C101 Lightning Mâle vers Jack 3.5mm Femelle 24bit 48kHz
This DD TC35i 2022 smartphone adapter consists of a male Lightning connector and a female 3.5mm jack. It embeds a C101 DAC allowing an efficient conversion of the audio signal for an accurate sound reproduction, while supporting audio streams up to PCM 24bit 48kHz. Robust, the connector body is made of CNC machined aluminum.
Technical characteristics
Product typeAdapter and DAC
Connectors1x Male Lightning
1x Female Jack 3.5mm
DAC ChipC101
Supported sampling ratesPCM up to 24bit 48kHz
Output pwer16.8mW @ 30Ω
THD+N< -75dB
Dimensions18 x 17 x 9.8mm
Weight3.7g
InputLightning
OutputJack 3.5mm
DAC / ADC ChipC101
Max sampling rate48kHz
ColorBlue
Contacts Plating (Connector)N/A
This DD TC35i 2022 smartphone adapter consists of a male Lightning connector and a female 3.5mm jack. It embeds a C101 DAC allowing an efficient...
