Connects easily with my iPhone and with my 4.4mm balanced earphones. Decent sound quality
Adapter DAC CS43131 Male Lightning to Female Jack 4.4mm 32bit 384kHz DSD256
This TC44A DD adapter for smartphone is composed of a male Lightning connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio signal for a clear and precise reproduction, while supporting high resolution streams, up to PCM 32bit 384kHz and DSD256. The robust connector body is made of CNC machined aluminum. Its practical "T" shape allows for a compact design.
Product type | Adapter and DAC |
Connectors | 1x Male Lightning 1x Female Jack 4.4mm |
DAC Chip | CS43131 |
Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
Frequency response | 20Hz - 20kHz |
Output power | 60mW @ 32Ω |
Dynamic range | > 120dB |
THD+N | < -110dB |
SNR | > 120dB |
Dimensions | 19.5 x 21 x 12mm |
Weight | 5.5g |
Input | Lightning |
Output | Jack 4.4mm |
DAC / ADC Chip | CS43131 |
Max sampling rate | 384kHz |
Max sampling rate | DSD256 |
Color | Black |
Color | Blue |
Networking | No |
Remote Control | No |
Contacts Material (Connector) | N/A |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
