DD TC44A DAC CS43131 Male USB-C to Female Jack 4.4mm 32bit 384kHz DSD256
This TC44A DD adapter for smartphone is composed of a male USB-C connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio signal for a clear and precise reproduction.
Reference : 16997
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 23-04-2025.
DD TC44A
Adapter DAC CS43131 Male USB-C to Female Jack 4.4mm 32bit 384kHz DSD256
DD TC44A Adaptateur DAC CS43131 Mâle vers Jack 4.4mm Femelle 32bit 384kHz DSD256
This TC44A DD adapter for smartphone is composed of a male UB-C connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio signal for a clear and precise reproduction, while supporting high resolution streams, up to PCM 32bit 384kHz and DSD256. The robust connector body is made of CNC machined aluminum. Its practical "T" shape allows for a compact design.
The USB-C connector is connected to the internal PCB via high-purity OCC copper conductors.
Product typeAdapter and DAC
Connectors1x Male USB-C
1x Female Jack 4.4mm
DAC ChipCS43131
DSD up to DSD256
Output power60mW @ 32Ω
Dynamic range> 120dB
THD+N< -110dB
SNR> 120dB
Dimensions19.5 x 21 x 12mm
Weight5.5g
OutputJack 4.4mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateDSD256
ColorBlue
2 reviews
Très bon rapport encombrement / performances
Excellente qualité de fabrication, encombrement minuscule, son clair et détaillé, signature sonore neutre... Ce micro DAC/AMP fait très bien son boulot, il drive correctement des intras ou des casques à faible impédance.
This review has been posted for DD TC44A DAC CS43131 Male USB-C to Female Jack 4.4mm 32bit 384kHz DSD256
Simple yet effective
Very portable DAC that connects to my iPad Air and my 4.4mm balanced earphones. Sound quality is decent. Happy customer here
This TC44A DD adapter for smartphone is composed of a male USB-C connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient...
