DD TC44PRO E2 Portable DAC Lightning
Following on from the TC44B, TC44C and TC44Pro portable DACs for smartphones, DD HiFi unveils the TC44Pro E2, the fourth generation in its range. It features a male lightning connector and a balanced female 4.4mm jack. It features not one, but two CS43131 DACs.
Reference : 19255
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 25-04-2025.
DD TC44PRO E2 DAC Portable DAC 2x CS43131 Lightning Male to Balanced Jack 4.4mm Female 32bit 384kHz DSD256
TC44Pro E2 picture
Following on from the TC44B, TC44C and TC44Pro portable DACs for smartphones, DD HiFi unveils the TC44Pro E2, the fourth generation in its range. It features a male lightning connector and a balanced female 4.4mm jack. It features not one, but two CS43131 DACs for efficient digital/analog conversion of the audio signal, for clear, rich and precise reproduction. The TC44Pro E2 supports high sampling rates up to PCM 32 bit 384kHz and DSD256. The main new feature compared to the TC44Pro is that the TC44Pro E2 also incorporates two ES9603Q headphone drivers. This enables it to deliver more power while maintaining clear, rich sound reproduction.
DD TC44PRO E2: 4.4mm balanced jack
This HiFi DD product features a Pentaconn-format 4.4mm jack socket with a lead-free soldered connection containing 3% silver for improved conductivity. The upper part is reinforced by a metal ring to protect the connector effectively.
Photo de la sortie jack du TC44Pro E2
Photo de la LED du TC44 Pro E2
DD TC44PRO E2: Indicator LEDs
An indicator LED identifies the sampling rate of the file being played. The indicator lights up blue for PCM format and green for DSD format.
Product typePortable DAC
Connectors1* Lightning male
1* 4.4mm balanced female jack
DAC chips2* CS43131
Headphone drivers2* ES9603Q
Output power2x 250mW @ 32 ohm
SNR>125dB (A-wt)
Dynamic range> 120dB (A-wt)
THD+N<0.0004% @ 1kHz
Supported sample ratesPCM 32 bit 384kHz, native DSD up to DSD256
LED indicatorBlue : PCM
Green : DSD
Lightning cable length9cm
Dimensions60 x 20 x 10mm
Weight20.7g
ColorSilver
Package1x Portable DAC DD TC44PRO E2
InputLightning
OutputJack 4.4mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
DD TC44PRO E2 Portable DAC 2x CS43131 Lightning Male to Balanced Jack 4.4mm Female 32bit 384kHz DSD256
Following on from the TC44B, TC44C and TC44Pro portable DACs for smartphones, DD HiFi unveils the TC44Pro E2, the fourth generation in its range....
