DD TC44PRO Portable DAC 2x CS43131 Lightning Male to Jack 4.4mm Female 32bit 384kHz DSD256
20%
Following on from the TC44B and TC44C portable DACs for smartphones, DD HiFi has unveiled the TC44PRO, the third generation in its range. It features a male Lightning connector and a female 4.4mm jack. It features not one but two CS43131 DACs for efficient digital/analogue conversion of the audio signal for clear, rich and precise playback. The TC44PRO supports high sampling rates up to PCM 24 bit / 384kHz and DSD256.
Reduced price!
Reference : 17875
Limited time offer:
85,00 €tax incl.
-20%
68,00 €tax incl.
56,67 € tax excl.
Last items in stock !
Shipping date: 06-05-2025.
DD TC44PRO
 Portable DAC 2x CS43131 USB-C Male to Jack 4.4mm Female 32bit 384kHz DSD256
Following on from the TC44B and TC44C portable DACs for smartphones, DD HiFi has unveiled the TC44Pro, the third generation in its series. It features a male Lightning connector and a female Jack 4.4mm. It integrates not one but two CS43131 DACs for efficient digital/analogue conversion of the audio signal for clear, rich and precise playback. The TC44Pro supports high sampling rates up to PCM 24bit 384kHz and DSD256. The design features an aluminium shell and a panel made from 1800D carbon fibre, a flexible, lightweight material that dissipates heat and protects the internal circuitry.
DD TC44PRO DAC Portable 2x CS43131 Lightning Mâle vers Jack 4.4mm Femelle 32bit 384kHz DSD256
Balanced dual DAC design
The integration of the two CS43131 DACs and its totally balanced circuit design enable the TC44Pro to achieve very good performance in terms of signal transmission stability, an SNR of over 125dB and a dynamic range of over 120dB.
Indicator lights and leather strap
As well as being supplied with a practical leather strap, the TC44Pro has a luminous indicator that shows the playback format of the track currently being played. The indicator lights up blue for PCM format and green for DSD format.
Product typePortable DAC
Connectors1* Lightning male
1* Balanced Jack 4.4mm female
DAC Chips2* CS43131
Output power120mW  (@ 32Ω)
SNR> 125dB
Dynamic range> 120dB
THD+N≤ -110dB
Supported sample ratesPCM: up to 32bit 384kHz
Native DSD: DSD64 / DSD128 / DSD256
Dimensions30*18*12.5mm
Weight9g
ColorSilver
Input
  • Lightning
Output
  • Jack 4.4mm
DAC / ADC Chip
  • CS43131
Max sampling rate
  • 384kHz
  • DSD256
Color
  • Silver
Networking
  • No
Remote Control
  • No
Fantastique
Je cherchais un Dac pour pouvoir relier mon casque avec un câble symétrique 4,4mm à mon IPhone et je recommande ce produit le son est fabuleux les graves les médiums et les aigus sont à leur place on entend chaque détail. Je ne regrette pas mon achat et je le conseille à tous les amateurs de musique classique en plus le prix n’est pas excessif compte tenu de la qualité. Foncez si vous souhaitez améliorer le son de votre iPhone.
This review has been posted for DD TC44PRO Portable DAC 2x CS43131 Lightning Male to Jack 4.4mm Female 32bit 384kHz DSD256
Following on from the TC44B and TC44C portable DACs for smartphones, DD HiFi has unveiled the TC44PRO,...
