fonctionne très bien avec Qobuz sur usb audio player pro, j'utilise des earsonics éléments depuis 1 mois le rendu est dynamique et détaillé. à voir avec mes em2pro, quand ils seront revenus du SAV....
Following on from the TC44B and TC44C portable DACs for smartphones, DD HiFi has unveiled the TC44Pro, the third generation in its range. It features a male USB-C connector and a female balanced Jack 4.4mm. It features not one but two CS43131 DACs for efficient digital/analogue conversion of the audio signal, for clear, rich and precise playback. The TC44Pro supports high sampling rates up to PCM 24bit 384kHz and DSD256. The design features an aluminium shell and a panel made from 1800D carbon fibre, a flexible, lightweight material that dissipates heat and protects the internal circuitry.
The integration of the two CS43131 DACs and its totally balanced circuit design enable the TC44Pro to achieve very good performance in terms of signal transmission stability, an SNR of over 125dB and a dynamic range of over 120dB..
As well as being supplied with a practical leather strap, the TC44Pro has a luminous indicator that shows the playback format of the track currently being played. The indicator lights up blue for PCM format and green for DSD format.
Product type | Portable DAC |
Connectors | 1* Male USB-C 1* Balanced female Jack 4.4mm |
DAC chips | 2* CS43131 |
Output power | 120mW (@ 32Ω) |
SNR | > 125dB |
Dynamic range | > 120dB |
THD+N | ≤ -110dB |
Supported sample rates | PCM: up to 32bit 384kHz Native DSD: DSD64 / DSD128 / DSD256 |
Dimensions | 30*18*12.5mm |
Weight | 9g |
Color | Silver |
Input | USB |
Output | Jack 4.4mm |
DAC / ADC Chip | CS43131 |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Silver |
Networking | No |
Remote Control | No |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Anthony B.
