DD TC35M2 Adapter DAC Headphone Amplifier
The TC35M2 from ddHiFi is a portable DAC and amplifier for headphones. The latter is equipped with an ESS ES9603Q amplifier chip, delivering 2x45mW of power at 32 Ohm, capable of driving the vast majority of headphones on the market. Its digital-to-analog conversion stage supports files up to 384kHz PCM for faithful, detailed reproduction.
Reference : 19680
35,99 €tax incl.
29,99 € tax excl.
Shipping date: 24-04-2025.
DD TC35M2 Adapter DAC Headphone Amplifier USB-C Male to Jack 3.5mm Female 32bit 384kHz
DD TC35M2 : Front and back views
The TC35M2 from ddHiFi is a portable DAC and amplifier for headphonesThe latter is equipped with an ESS ES9603Q amplifier chip, delivering 2x45mW of power at 32 Ohm, capable of driving the vast majority of headphones on the market. Its digital-to-analog conversion stage supports files up to 384kHz PCM for faithful, detailed reproduction.
Product typePortable DAC
Headphone amplifier
Connectors3.5mm female jack
USB-C male
Total harmonic distortion more noise (THD+N)<0.008% @32Ω
Amplifier chipES9603Q
Dynamic range>120dB
Signal-to-noise ratio (SNR)≥112dB @32Ω
Output power45mW+45mW @32Ω
Noise level<3µV
Housing materialAluminium alloy
Dimensions17.8 x 14 x 8.9mm
Weight3.6g
ColorGrey
Package1x DD TC35M2
OutputJack 3.5mm
DAC / ADC ChipES9603Q
Max sampling rate384kHz
ColorGray
DDTC35M2 adaptateur dac
Bien reçu mon produit commandé vendredi 15/11, reçu en colissimo jeudi 21/11/24, bravo.
J'ai acheté cet adaptateur pour mon smartphone, associé à ma plate-formeTidal et mon casque beyerdynamic DT 770 Pro X édition limitée, il fait super bien le job, la qualité de son est sublime mon casque fait 48 ohms. Je vous le conseille.
Cdt.
This review has been posted for DD TC35M2 Adapter DAC Headphone Amplifier USB-C Male to Jack 3.5mm Female 32bit 384kHz
The TC35M2 from ddHiFi is a portable DAC and amplifier for headphones. The latter is equipped with an ESS ES9603Q amplifier chip, delivering 2x45mW...
