With the TC44PRO M3, ddHifi presents a portable DAC based on two CS43198 DAC chips from Cirrus Logic with a sleek design and a single-ended 3.5mm and balanced 4.4mm jack output. This small portable DAC is capable of handling a signal up to PCM 32bit 384kHz and DSD256, and is designed to accompany you wherever you go and adapt to any situation.
For its digital-to-analogue conversion, the TC44PRO M3 relies on two Cirrus Logic CS43198 DAC chips, providing signal support up to PCM 32bit 384kHz and DSD256. In terms of amplification, the Cirrus Logic chips deliver an output power of 90mW at 32Ω single-ended and 120mW at 32Ω balanced.
To ensure broad compatibility with the widest range of headphones and earphones, the TC44PRO M3 incorporates a single-ended 3.5mm jack and balanced 4.4mm jack output, allowing you to enjoy the benefits of balanced output while ensuring that you can always use this device whatever the situation and whatever equipment you have access to.
The TC44PRO M3 adopts the aesthetic lines of ddHiFi's Surface product series. Its textured, angular aluminium alloy body creates a harmonious balance between minimalism and sophistication.
To ensure that you always know at a glance which sampling rate is being used, the TC44PRO M3 is equipped with a colour-coded LED to indicate which lossless format is being used: Blue for PCM and Green for DSD.
To take you anywhere, the TC44PRO M3 comes with a stylish leather strap, making it easy to carry or attach anywhere.
Product type | Portable DAC |
Connectors | 1x Male USB-C 1x Female balanced 4.4mm jack 1x Female single-ended 3.5mm jack |
DAC chips | 2x CS43198 |
Output power | Balanced: 120mW @ 32Ω Single-ended: 90mW @ 32Ω |
Signal-to-noise ratio (SNR) | 125dB |
Dynamic range | 120dB |
Total harmonic distortion (THD) | -110dB |
Supported sampling rates | PCM: up to 32 Bit 384kHz Native DSD: DSD64 / DSD128 / DSD256 |
Dimensions | 30.4 x 12.4 x 17mm |
Weight | 11g |
Color | Grey |
Package | 1x ddHiFi TC44PRO M3 1x Leather strap |
Input | USB |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
DAC / ADC Chip | CS43198 |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Gray |
Networking | No |
Remote Control | No |
