FIIO E10K TC USB DAC Mobile headphone amplifier 32Bit / 384kHz XMOS XUF208
Taking advantage of Fiio's know-how, this E10K TC version inherits the latest XMOS XUF208 chip, allowing high sampling rates of 32 bit / 384kHz, thanks to its USB-C input.
Reference : 15585
89,00 €tax incl.
74,17 € tax excl.
FIIO E10K TC
Mobile Headphone Amplifier and Nomadic DAC
FIIO E10K TC DAC
The FIIO E10K TC is the successor to the E10K, a mobile headphone amplifier and nomadic DAC, offering excellent performance in a compact format.
Taking advantage of Fiio's know-how, this version inherits the latest XMOS XUF208 chip, allowing to reach high sampling rates of 32 bit / 384kHz, thanks to its USB-C input.
This new Fiio product is a real Swiss army knife, you can use it as a desktop DAC, a nomadic DAC, a desktop headphone amplifier or a nomadic headphone amplifier.
It offers a USB-C input, for a choice of 3 outputs: SPDIF Coaxial, 3.5mm jack line level (2Vrms), and a 3.5mm jack headphone output also on the front panel.
The two 3.5mm jack outputs are downstream of a PCM5102 DAC chip that can read high-resolution files: 24bit/96kHz without a driver, and 32bit/384kHz with XMOS driver for Windows.
Fiio E10K TC
FEATURES
TypeHeadphone amplifier and DAC
Volume controlVia ALPS potentiometer (from -90dB to 0dB)
DACPCM5102 Burr Brown
InputUSB-C
Outputs1x 3.5mm analog line level jack (2Vrms)
1x 3.5mm headphone jack
1x SPDIF Coaxial digital
Signal to noise ratio114dB
Accepted sampling rates32Bit / 384khz
Headphone amplificationLMH6643 + OPA1662
Accepted headphone impedances16 - 150 Ohm
Output impedance< 1.2 Ohm (32 Ohm)
Power output219mW sous 32 Ohm
GainL : +1.6dB / H : +8.8dB
Bass boostingOFF : 0dB / ON : +3dB
Supply voltage5V 500mA (Via USB)
Dimensions79x21x49mm
Weight78g net
Package contents
E10K TCx1
Mini-USB to USB cablex1
Cable 3.5mm jack angled to 3.5mm jack angledx1
Manualx1
Anti-slip rubber padx4
OutputJack 3.5mm
OutputCoaxial SPDIF
Interface chipNC
Taking advantage of Fiio's know-how, this E10K TC version inherits the latest XMOS XUF208 chip, allowing high sampling rates of 32 bit /...
