FiiO Q1 DAC Portable USB DAC & Headphone Amplifier PCM5102 24bit / 96kHz
Reference : 10299
79,00 €tax incl.
65,83 € tax excl.
The FiiO Q1 is a portable DAC / Amplifier that stands out for its ergonomics and design as well as its design and electronic architecture.
Equipped with a USB interface that can support PCM audio files up to 24bit 96kHz, the Q1 can also be used as an external computer sound card.
It is equipped with a converter PCM5102 having the peculiarity of having a high signal-to-noise ratio and a low distortion associated with an amplification stage composed of a MAXIM MAX97220 amplifier.
This association presents all the assets of DAC and Amplifiers helmets high-end competitors.
The Micro USB port not only allows you to load and transfer audio, but also to connect it to future FiiO products.
This DAC USB / Headphone Amplifier is compatible with iOS and Android devices.
Characteristics :
  • DAC: PCM5102
  • Supported PCM audio files up to 24bit 96kHz
  • Amplification via MAXIM MAX97220
  • Inputs: Micro USB, 3.5mm Jack Line
  • Outputs: Line, 3.5mm Headphone Jack
  • Recommended impedance: 16 - 150 Ohm
  • Volume control via TOCOS potentiometer
  • Bass function (0 / 5dB)
  • Output power: 190mW (32 Ohm), 75mW (150 Ohm)
  • THD + N: <0.005% at 1kHz
  • Input Sensitivity: 4.3V (Gain Low), 1.5V (Gain High)
  • Gain: -7dB/ 4.5dB (AUX IN), -3.5dB / 8dB (USB IN)
  • Input voltage max. :> 4Vrms
  • Output voltage max. : 7.2 Vp-p
  • Output current max. :> 75mA
  • Output impedance: <0.3 Ohm
  • Frequency response: 20Hz - 20kHz
  • Signal Noise Ratio:> 107dB
  • Power Supply: 5V DC 1A
  • Battery Life (1400mA): 30h
  • Charging time: 4h
  • Chassis Brushed aluminum, black sandblasted
  • Dimensions: 97x56x13mm
  • Weight: 100g
  • 3.5mm 3.5cm Jack-Jack cable, USB-A to micro USB cable and support rubbers provided.
Head-Fi
Test in English (Click here)
