HIDIZS S9 PRO PLUS MARTHA Headphone Amplifier Portable Balanced DAC Blue
Hidizs unveils its S9 Pro Plus Martha, an evolution of the S9 Pro, a powerful, high-performance balanced portable DAC headphone amplifier. It features a fully balanced structure: a USB input interface, an ES9038Q2M DAC chip, an independent headphone amplifier and anti-POP protection. These features enable it to support high-resolution streams up to PCM 32bit 768kHz and native DSD up to DSD512, with output power up to 2x 180mW @ 32ohm on its balanced output.
Reference : 18926
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 22-04-2025.
HIDIZS S9 PRO PLUS MARTHA Portable Balanced DAC Headphone Amplifier ES9038Q2M 32bit 768kHz DSD512 Blue
Photo of the Hidizs S9 Pro Plus Martha portable DAC headphone amplifier
Hidizs unveils its S9 Pro Plus Martha, an evolution of the S9 Pro, a powerful, high-performance balanced portable DAC headphone amplifier. It adopts an audiophile architecture specially developed by Hidizs Acoustic Laboratory, with a fully balanced structure consisting of 4 distinct parts: a USB input interface, an ES9038Q2M DAC chip, an independent headphone amplifier and anti-POP protection. These features enable it to support high-resolution streams up to PCM 32bit 768kHz and native DSD up to DSD512, with output power up to 2x 180mW under 32ohm on its balanced output.
Hidizs S9 Pro Plus Martha highlights
S9 Pro Plus Martha
S9 Pro
S9
DAC
ES9038Q2M
ES9038Q2M
AK4493EQ
Outputs
Jack 3.5mm + Jack 4.4mm
Jack 3.5mm + Jack 2.5mm
Light indicator
Yes
Yes
Yes
Max PCM sampling rate
32bit 768kHz
32bit 768kHz
32bit 768kHz
Max. DSD sampling rate
DSD512
DSD512
DSD512
SNR
Jack 3.5mm : 123dB @ 32Ω
Jack 4.4mm : 120dB @ 32Ω
Jack 3.5mm : 120dB @ 32Ω
Jack 2.5mm : 119dB @ 32Ω
Jack 3.5mm : 119dB @ 32Ω
Jack 2.5mm : 117dB @ 32Ω
Channel separation
Jack 3.5mm : 75dB @ 32Ω
Jack 4.4mm : 115dB @ 32Ω
Jack 3.5mm : 80dB @ 32Ω
Jack 2.5mm : 118dB @ 32Ω
Jack 3.5mm : 79dB @ 32Ω
Jack 2.5mm : 114dB @ 32Ω
THD+N
Jack 3.5mm : 0.0019% @ 32Ω
Jack 4.4mm : 0.0008% @ 32Ω
Jack 3.5mm : 0.0006% @ 32Ω
Jack 2.5mm : 0.0012% @ 32Ω
Jack 3.5mm : 0.0018% @ 32Ω
Jack 2.5mm : 0.006% @ 32Ω
Output power
Jack 3.5mm : 138mW @ 32Ω
Jack 4.4mm : 180mW @ 32Ω
Jack 3.5mm : 100mW @ 32Ω
Jack 2.5mm : 200mW @ 32Ω
Jack 3.5mm : 90mW @ 32Ω
Jack 2.5mm : 120mW @ 32Ω
HIDIZS S9 PRO PLUS MARTHA: ES9038Q2M DAC chip
Inside this balanced portable DAC headphone amplifier is an ESS Technology ES9038Q2M DAC chip based on the 32-bit Hyperstream II QUADDAC architecture and Time Domain Jitter Eliminator technology. The characteristics of this DAC enable the S9 Pro Plus Martha to support 32bit 768kHz PCM and DSD512 streams, with sound reproduction featuring an SNR of up to 128dB and a THD+N of -120dB.
Photo of ES9038Q2M DAC chip
Photo of the headphone outputs of the Hidizs S9 Pro Plus Martha
HIDIZS S9 PRO PLUS MARTHA: a high-performance headphone amplifier
The Martha S9 Pro Plus features two headphone outputs, a 3.5mm jack and a balanced 4.4mm jack, enabling it to adapt to different types of headphones. In terms of power level, it is capable of delivering up to 2x 138mW @ 32 ohm on its 3.5mm jack output, and up to 2x 180mW @ 32 ohm on its 4.4mm jack output. Distortion on the 3.5mm jack output is just 0.0019%, while the balanced output achieves ultra-low distortion of 0.0008% and channel separation of 75dB/115dB respectively - top-level performance for a portable device weighing no more than 20g.
HIDIZS S9 PRO PLUS MARTHA: simplified controls and filters
The Hidizs S9 Pro Plus Martha's interface features two rotary knobs that allow you to access controls such as volume adjustment and 6 PCM filters by pressing them simultaneously. These filters enable her to adapt to your tastes, the type of tracks you're listening to, as well as to the various IEMs and headphones on the market. Here are the available filters:
  • Green (Default Filter) : Anodizing fast roll-off, vocals are slightly forward, and high frequencies are extended with reduced resonance.
  • Red : Linear phase fast roll-off, enhanced analytical capabilities, delivering a clean and crisp sound.
  • Blue : Linear phase slow roll-off, enriched harmonics, full low frequencies, and natural reverb.
  • Yellow : Minimum phase fast roll-off, balanced and moderate sound.
  • Purple : Minimum phase slow roll-offClean sound with a forward position.
  • White : Hybrid fast roll-off, soft and smooth sound with enhanced detail.
Photo of Hidizs S9 Pro Plus Martha
HIDIZS S9 PRO PLUS MARTHA: a high level of system compatibility
The S9 Pro Plus Martha's USB-C input port enables it to work with a wide range of plug-and-play systems: Windows, Mac OS, Android, IOS, Harmony OS.
HIDIZS S9 PRO PLUS MARTHA: an RGB LED indicator
The LED indicator logo is not only used to select the different filters available. It also indicates the type of stream being played, thanks to its different colors:
  • Yellow : DSD 64/128
  • Purple : DSD 256/512
  • Blue : PCM 176.4/192kHz
  • Red : PCM 352.8/384kHz
  • White : PCM 705.6/768kHz
  • Green : PCM 44.1/48/88.2/96kHz
Hidizs S9 Pro Plus Martha LED colors
Product typePortable DAC headphone amplifier
DAC chipES9038Q2M
Input1x USB-C
Ouputs1x 3.5mm jack headphone output
1x 4.4mm jack balanced headphone output
Supported sample rates32bit 768kHz PCM and native DSD up to DSD512
System compatibilityWindows, Mac OS, IOS , Android, Harmony OS
Output powerUnbalanced output: 2x 138mW @ 32 ohm
Balanced output: 2x 180mW @ 32 ohm
Frequency response20Hz - 40Khz
DistorsionUnbalanced output: 0.0019%
Balanced output: 0.0008%
SNRUnbalanced output: 123dB
Balanced output: 120dB
Channel separationUnbalanced output: 75dB
Balanced output: 115dB
Dimensions55 x 25 x 11mm
Net weight17g
ColorBlue
Package1x Hidizs S9 Pro Plus Martha portable DAC headphone amplifier
1x USB-C to USB-C cable
1x USB-C to USB-A adapter
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
ColorBlue
ClassN/A
Hidizs unveils its S9 Pro Plus Martha, an evolution of the S9 Pro, a powerful, high-performance balanced portable DAC headphone amplifier. It...
