HIDIZS SD2 Portable DAC Headphone Amplifier Black
The Hidizs SD2 is a versatile, high-performance USB-C to 3.5mm jack portable headphone amplifier and DAC dongle. Equipped with an independent ESS ES9270 DAC chip, it supports PCM streams up to 32bit 384kHz and native DSD up to DSD128. So you can enjoy top-quality sound reproduction, even on the move.
4.0 / 5
Reference : 19018
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 22-04-2025.
Hidizs SD2 Portable DAC Headphone Amplifier USB-C to Jack 3.5mm ES9270 32bit 384kHz DSD128 Black
Hidizs SD2 portable DAC
Hidizs SD2: Numerous application scenarios
Hidizs SD2: A versatile portable DAC and headphone amplifier
Hidizs SD2: A versatile dongle
The SD2, with its standard USB-C interface, connects seamlessly to smartphones, computers, tablets and consoles, acting as a versatile external sound card and amplifier. Its 3.5mm jack headphone socket supports direct connection of wired headphones or to external active speakers, delivering maximum power of 2x70mW at 32Ω.
Hidizs SD2 : Compatible avec de nombreux appareils
Hidizs SD2 : Compatible iPhone 15
Hidizs SD2: Enhance the sound of your smartphone
By adopting the international USB-C standard, the Hidizs SD2 can be plugged into all modern smartphones. So you can enhance your audio experience on the move. Compact at 34.5x20x10mm, the Hidizs SD2 is quickly forgotten once installed.
Hidizs SD2: Support for controls and built-in microphone
The Hidizs SD2 not only supports cable remote control, but is also equipped with a high-definition microphone. When plugged in, the SD2 converts the microphone's audio stream to 24bit 48kHz, guaranteeing clear voice transmission.
Hidizs SD2: control support and built-in microphone
Hidizs SD2 : ES9270 DAC chip
Hidizs SD2: Independent ES9270 DAC chip
The Hidizs SD2 is equipped with ESS Technology's ES9270 digital-to-analog conversion chip, featuring the patented HyperStream II architecture. It supports PCM streams up to 32bit 384kHz and native DSD up to DSD128, and incorporates a 2x70mW headphone amplifier. With distortion of just 0.0015%, SNR of 118dB and channel separation of 64dB, the SD2 guarantees balanced, clear and expressive sound with a wide soundstage.
Hidizs SD2: Next-generation design and aluminum shell
The SD2 features an aluminum alloy chassis, designed using a unique etching technique, creating a futuristic appearance with clean lines and geometric shapes to great effect. The 3.5mm audio jack, carefully angled at 45 degrees, optimizes the experience by harmoniously combining style and functionality. The SD2's compact construction and weight of just 6 grams ensure exceptional portability, ideal for use on the move.
Hidizs SD2: Compatibility with all OSes
Hidizs SD2: Extended compatibility
Hidizs SD2 enhances audio output on different devices, offering a seamless experience for multimedia, music or gaming. Compatible with Windows, iOS, Android, HarmonyOS and more, it guarantees a quality sound experience. Simply plug in earphones or headphones and immerse yourself in the sound.
Hidizs SD2 : LED indicator
Despite its compact design, the SD2 incorporates an LED sample rate indicator for quick identification of the type of stream being played.
Red: PCM 44.1-48kHz
Blue: PCM 88.2-384kHz / DSD64-128
Hidizs SD2: LED indicator
Hidizs SD2: Equalizer compatibility
Hidizs SD2: Integrated equalizer support
The SD2 is compatible with the built-in equalization functions of various music applications. This feature enables it to bypass the built-in audio processing of mobile devices such as smartphones and tablets, and deliver an authentic, high-fidelity audio experience.
Hidizs SD2: Hi-Res certification
The Hidizs SD2 is Hi-Res Audio certified, guaranteeing high-quality sound reproduction and support for high-resolution streams.
Product typePortable DAC and headphone amplifier
DAC chipESS ES9270
InputUSB-C
OutputJack 3.5mm
Native DSD up to DSD128
LED indicatorRed: PCM 44.1-48kHz
Blue: PCM 88.2-384kHz & DSD
Frequency response20Hz - 40kHz
Distortion0.0015%
SNR118dB
Channel separation64dB
Output powerUp to 2x70mW
Shell materialAluminum alloy and resin
Supported OSAndroid
iOS
Windows
Mac OS
Harmony OS
Weight6g
Package1x Hidizs SD2
1x USB-C to USB-A adapter
OutputJack 3.5mm
DAC / ADC ChipES9270
Max sampling rateDSD128
Max sampling rate384kHz
ClassN/A
Good...
Good sound, strange shape (and you have to put it in the right position...) but good.
This review has been posted for HIDIZS SD2 Portable DAC Headphone Amplifier USB-C to Jack 3.5mm ES9270 32bit 384kHz DSD128 Black
The Hidizs SD2 is a versatile, high-performance USB-C to 3.5mm jack portable headphone amplifier and DAC dongle. Equipped with an independent ESS...
