HIDIZS XO Portable DAC Headphone Amplifier 2x ES9219C Balanced 32bit 384kHz DSD256 MQA Silver
30%
The Hidizs XO is the ideal companion to accompany a smartphone and enjoy a high quality sound reproduction. Combo DAC and portable headphone amplifier, it benefits from very good performances and a neat design, perfect to listen to your music in the best conditions, especially on the move. It even provides a double balanced / single-ended output to fit all headphones and earphones.
Reduced price!
Reference : 17330
Limited special offer
99,00 €tax incl.
-30%
69,30 €tax incl.
57,75 € tax excl.
Last items in stock !
Shipping date: 22-04-2025.
Hidizs XO
Hidizs XO DAC Amplificateur Casque Portable 2x ES9219C Symétrique 32bit 384kHz DSD256 MQA
Dual ES9219C DAC & Independant clock
The digital to analog conversion section of the Hidizs XO uses two Sabre ESS ES9219C DAC chips, one per channel, to provide high precision decoding. This accuracy is further enhanced by the association of a powerful independent oscillator with these chips, which allows a drastic reduction of jitter. Furthermore, the DAC supports high-resolution audio streams up to 32bit 384kHz PCM and DSD256 as well as MQA file decoding for the most transparent sound reproduction possible.
MQA 16X
The Hidizs XO supports MQA (Master Quality Authenticated) technology, allowing for a sound reproduction as close as possible to the original studio recording. It is able to decode and playback these files up to MQA 16X to provide you with unparalleled music quality.
Filter selection
The circular button on the front of the XO allows you to change the filtering mode on the fly, without the need to use an external application or to update the device's firmware. You can thus adapt the XO's sound reproduction to your taste and your listening device.
Innovative design
The Hidizs XO features a high-density aluminum alloy shell designed using a 5-axis CNC process. The two sides of the device are engraved with great precision, revealing a beautiful diffuse LED lighting.
Balanced & Single-ended
Despite its compactness and light weight, the Hidizs XO provides two outputs: one in single-ended Jack 3.5mm format and the second in balanced Jack 2.5mm format. It can be connected to your headphones or earphones, both balanced and single-ended. It also delivers enough power to accompany many headphones, up to 300Ω.
Sample rate indicator light
The circular button on the front panel of the XO is surrounded by an LED indicator displaying in real time, according to its color, the sampling rate and the format of the file being played.
  • Green : PCM 44.1/48/88.2/96kHz
  • Yellow : PCM 176.4/192kHz
  • Red : PCM 352.8/384kHz
  • Blue : DSD 64/128/256
  • Purple : MQA
Product typePortable DAC and headphone amplifier
Input1* USB-C
Outputs1* Single-ended Jack 3.5mm
1* Balanced Jack 2.5mm
DAC chips2* ESS ES9219C
DSD up to DSD256
MQA supportMQA 16X
Frequency responseSingle-ended: 20Hz-40kHz (±0.12dB)
Balanced: 20Hz-40kHz (±0.12dB)
THD+NSingle-ended: 0.0015%
Balanced: 0.0005%
SNRSingle-ended: 118dB
Balanced: 119dB
CrosstalkSingle-ended: 76dB
Balanced: 118dB
OS CompatibilityAndroid
iOS (requires Lightning to USB-C OTG cable not included)
Windows
Mac OS
Dimensions55*24.5*9.35mm
Weight11g
ColorSilver
Package1* Hidizs XO
1* USB-C cable
1* USB-C to USB-A adapter
OutputJack 2.5mm
OutputJack 3.5mm
DAC / ADC ChipES9219C
Max sampling rate384kHz
Max sampling rateMQA
Max sampling rateDSD256
ColorSilver
The Hidizs XO is the ideal companion to accompany a smartphone and enjoy a high quality sound reproduction. Combo DAC and portable headphone...
