IBASSO DC03Pro Portable DAC Headphone Amplifier 2x CS43131 USB-C 32bit 384kHz DSD256 Gray
With the DC03Pro, iBasso offers a portable DAC and headphone amplifier combo as compact as it is powerful. Thanks to an optimized design based on the use of quality components, it will allow you to enjoy an excellent listening experience even on the move!
Reference : 16982
79,00 €tax incl.
65,83 € tax excl.
iBasso DC03Pro
iBasso DC03Pro DAC Amplificateur Casque Portable 2x CS43131 USB-C 32bit 384kHz DSD256 Gris
Dual CS43131 DAC
The DC03Pro embeds two CS43131 digital-to-analog conversion chips from Cirrus Logic. This model, the flagship of the manufacturer, takes advantage of HiFiT™ technology ensuring incredible performance for a sound of great precision.
Femtosecond KDS Clock
Equipped with a KDS femtosecond oscillator, the DC03Pro offers low phase noise thanks to a highly accurate clock signal. It also allows a significant reduction of jitter, favoring a beautiful sound transparency.
iBasso UAC App
iBasso provides the free Android application iBasso UAC. It allows you to adjust the volume and balance of the DC03Pro, to access 5 digital filters or to adjust the gain level.
Low power consumption
The DC03Pro uses a highly efficient power supply management chip and a DC-DC converter to control and minimize power consumption.
USB-C Input & Jack 3.5mm Output
For its connectivity, the DC03Pro is equipped with a USB-C port at the input and a 3.5mm stereo jack at the output. It is designed to make up for the lack of the latter on many current smartphones, while allowing you to enjoy a much improved sound reproduction.
Product typePortable DAC and headphone amplifier
DAC Chips2* Cirrus Logic CS43131
Input1* USB-C
Output1* Jack 3.5mm
THD+N-114dB @ 300Ω
-111dB @ 32Ω
Output voltage2Vrms @ 300Ω
1.77Vrms @ 32Ω
SNR127dB
Dynamic range122dB
Frequency response20Hz~40kHz ±0.5dB
Noise floor0.9µV
Output impedance< 0.12Ω
Native DSD up to DsD256
Dimensions (L*P*H)49.4*21*8mm
Weight10.5g
ColorGris
Package1* iBasso DC03Pro
1* USB-C to USB-C cable
1* USB-C to USB-A adapter
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateDSD256
ColorGray
Avis sur le Ibasso Dc03 Pro
Très bon produit pour mon pc portable. Améliore grandement la qualité du son, accompagné d'un bon casque. Son précis, détaillé. Produit étonnant pour le prix.
This review has been posted for IBASSO DC03Pro Portable DAC Headphone Amplifier 2x CS43131 USB-C 32bit 384kHz DSD256 Gray
With the DC03Pro, iBasso offers a portable DAC and headphone amplifier combo as compact as it is powerful. Thanks to an optimized design based on...
