utilisation sur pc portable et iphone14 pro max .flac 16 et 24 bits bonne restitution sur HD 599 et ROG cetra II en attente d'évolution ...
Bonne finition général , néanmoins un jeu au niveau de usb-c !
Portable DAC Headphone Amplifier 2x CS43131 USB-C 32bit 384kHz DSD256 Silver
With the DC03Pro, iBasso offers a portable DAC and headphone amplifier combo as compact as it is powerful. Thanks to an optimized design based on the use of quality components, it will allow you to enjoy an excellent listening experience even on the move!
The DC03Pro embeds two CS43131 digital-to-analog conversion chips from Cirrus Logic. This model, the flagship of the manufacturer, takes advantage of HiFiT™ technology ensuring incredible performance for a sound of great precision.
Equipped with a KDS femtosecond oscillator, the DC03Pro offers low phase noise thanks to a highly accurate clock signal. It also allows a significant reduction of jitter, favoring a beautiful sound transparency.
iBasso provides the free Android application iBasso UAC. It allows you to adjust the volume and balance of the DC03Pro, to access 5 digital filters or to adjust the gain level.
The DC03Pro uses a highly efficient power supply management chip and a DC-DC converter to control and minimize power consumption.
For its connectivity, the DC03Pro is equipped with a USB-C port at the input and a 3.5mm stereo jack at the output. It is designed to make up for the lack of the latter on many current smartphones, while allowing you to enjoy a much improved sound reproduction.
Product type | Portable DAC and headphone amplifier |
DAC Chips | 2* Cirrus Logic CS43131 |
Input | 1* USB-C |
Output | 1* Jack 3.5mm |
THD+N | -114dB @ 300Ω -111dB @ 32Ω |
Output power | 98mW @ 32Ω |
Output voltage | 2Vrms @ 300Ω 1.77Vrms @ 32Ω |
SNR | 127dB |
Dynamic range | 122dB |
Frequency response | 20Hz~40kHz ±0.5dB |
Noise floor | 0.9µV |
Output impedance | < 0.12Ω |
Supported sampling rates | PCM up to 32bit 384kHz Native DSD up to DsD256 |
Dimensions (L*P*H) | 49.4*21*8mm |
Weight | 10.5g |
Color | Silver |
Package | 1* iBasso DC03Pro 1* USB-C to USB-C cable 1* USB-C to USB-A adapter |
Input | USB |
Output | Jack 3.5mm |
DAC / ADC Chip | CS43131 |
Max sampling rate | 384kHz |
Max sampling rate | DSD256 |
Color | Silver |
Class | Class D / T |
Networking | No |
Remote Control | No |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Vincent D.
