IBASSO DC07PRO Balanced DAC Headphone Amplifier Black
The DC07Pro is the new version of iBasso's portable DAC/headphone amplifier. This compact device is equipped with four CS43131 chips and a custom-built FPGA, enabling it to read files up to PCM 32bit 768kHz and DSD512. Its low power consumption and high output level of 2x430mW at 32Ω make it the perfect travel companion.
4.3 / 5
Reference : 19619
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 29-09-2026.
iBasso DC07Pro Balanced DAC Headphone Amplifier 4x CS43131 32bit 768kHz DSD512 Black
IBASSO DC07PRO : Front view
iBasso DC07Pro: Custom FPGA
The DC07Pro uses FPGA technology developed in-house by iBasso, integrating audio algorithms and controlling the DAC/preamplifier system. As the heart of the DC07Pro, the FPGA system plays an essential role in regenerating the signal and synchronising it to the internal clock. It should also be noted that the FPGA system also generates a low-jitter clock signal for the DAC and USB signal processing, effectively reducing the jitter caused by the USB port.
IBASSO DC07PRO : FPGA
IBASSO DC07PRO : CS43131 DAC Chips
iBasso DC07Pro: 4 DAC chips
To effectively complement iBasso's FPGA system, the DC07Pro is equipped with four Cirrus Logic CS43131 DAC chips, delivering truly impressive measurement performance. Indeed, the DC07Pro's harmonic distortion more noise figure is just 0.000098% for an output level of 2x430mW at 32Ω. Furthermore, thanks in part to the FPGA used, the DC07Pro supports DSD512 and 32bit 768kHz PCM.
iBasso DC07Pro: Quality power supply
The DC07Pro uses a synchronous DC/DC converter with an efficiency rate of 94%, ensuring minimal heat generation. Furthermore, the DC07Pro consumes just 80mA of power - 40% less than the DC04PRO - and delivers 82% more output. The DAC's power supply stage adopts a very low-noise voltage regulator dedicated to the analogue circuit with a PSRR (Power Supply Rejection Ratio) of up to 100dB, guaranteeing a perfectly clean power supply. Finally, it's also worth noting that the DC07Pro's low power consumption makes it de facto compatible with IPhones, as it does not trigger the latter's power consumption safety device.
IBASSO DC07PRO : Representation of the 94% efficiency rate
IBASSO DC07PRO : Macro view of the multifunction knob
iBasso DC07Pro: Intuitive navigation
The DC07Pro has a 0.96-inch OLED screen and is equipped with an ALPS encoder. The multifunction knob allows you to scroll through and make all the settings. Simply turn and press the multifunction knob to adjust volume, digital crossover and more. Furthermore, the DC07Pro also supports the iBasso UAC Android application, which allows you to control all settings using your Android device.
Product typeDAC and portable headphone amplifier
InputUSB-C
Outputs1x Single-ended 3.5 mm jack
1x Balanced 4.4mm jack
DAC chips4x CS43131
Supported sampling ratesPCM 32bit up to 768kHz
DSD up to DSD512
Jack 4.4MM BALANCED OUTPUT
Total harmonic distortion more noise (THD+N)-120.2dB (0.000098%) @ 1kHz 300Ω
Output voltageLow gain: 2.8Vrms
Medium gain: 3.5Vrms
High gain: 4Vrms
Output power510mW + 510mW @ 16Ω THD+N<0.1%
430mW + 430mW @ 32Ω THD+N<0.1%
Signal-to-noise ratio134dB
Dynamic range134dB
Crosstalk142dB
Frequency response10Hz - 80kHz (-0.5dB)
Noise floor0.85µV
Jack 3.5MM SINGLE-ENDED OUTPUT
Total harmonic distortion more noise (THD+N)-116dB (0.00017%) @ 1kHz 300Ω
Output voltageLow gain: 1.4Vrms
Medium gain: 1.73Vrms
High gain: 2Vrms
Output power210mW + 210mW @ 16Ω THD+N<0.1%
118mW + 118mW @ 32Ω THD+N<0.1%
Signal-to-noise ratio129dB
Dynamic range129dB
Crosstalk136dB
Frequency response10Hz - 75kHz (-0.5dB)
Noise floor0.76µV
Dimensions59 x 23.5 x 12.5mm
Weight23g
Package1x iBasso DC07Pro
1x USB-C to USB-C cable
1x USB-C to Lightning cable
1x USB-C to USB-A adapter
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43131
Max sampling rateDSD512
Max sampling rate768kHz
3 reviews
Mieux qu'un DC06 mais ça n'est pas le miracle
Ce petit DAC rend bien mieux qu'un iBasso DC06 ou même qu'un iFi Hip Dac 3 (sans la puissance). Il est plus précis et plus détaillé. La scène est plus large et les instruments bien séparés mais la largeur de la scène n'est pas envoutante.
Je l'ai testé avec un Hifiman, le FiiO FT1 et un Audiotechnica MSR7. S'il drive le Hifiman mieux que le iBasso DC06 qui menance de flamber tellement le casque en demande, ce n'est pas non plus ce que j'ai lu ici et là. Il se débrouille bien avec le FiiO et l'Audiotechnica mais un bon setting est nécessaire sans quoi la les basses et les aigus s'envollent.
La molette est gènante, elle s'active dans la poche et n'est pas manipulable aisément avec une seule main.
L'écran affiche trop d'informations en même temps, ce qui rend les caractères trop petits.
Sur un smartphone Android (Nexus 7a) c'est une calamité, beaucoup plus "picky" que le DC06 ou le Hip Dac. A la moindre perte de signal, le driver audio est désactivé. Au démarrage de l'application, il faut parfois plug-unplug plusieurs fois pour que le driver se load correctement; un peu comme avec les Questyle, qui, eux, m'ont carrément rendu dingue.
Bref, c'est bien, c'est petit mais je le trouve surcoté dans les reviews. Il y a des inconvéniants et il faut le dire
This review has been posted for IBASSO DC07PRO Balanced DAC Headphone Amplifier 4x CS43131 32bit 768kHz DSD512 Black
Dac complètement incroyable
Je rejoins absolument le premier avis !!
Comment vous dire, j'ai voulu le comparer... J'ai donc écouté sur du matos meilleur que le mien les propositions en magasins à Paris (j'ai quand même un ampli Cambridge, des enceintes B&W détaillées) et constat dingue :
Son meilleur selon mon humble avis que les Dacs EverSolo même le meilleur modèle (son décharné à côté), Atoll même celui à deux mille euros quelque chose, ibasso meilleur, j'ai poussé la comparaison avec un Dac élitiste un Dac Moon à 2800 euros: il y avait évidence qu'Ibasso le survolait en terme de fidélité et de dynamisme, malgré tout le boniment du vendeur (c'est le seul l'ibasso qui permet d'entendre réellement de manière réaliste de la pluie tomber sur "the road to hell" de Chris Rea et je connais le morceau depuis 20 ans
Un petit DAC peut en cacher un grand...
Voulant un convertisseur transportable, mais quand même de qualité, j'ai tenté ma chance avec cet iBasso.
J'avais bien aimé le son du DC03, regrettant juste le câble non amovible, qui a du coup lâché.
Ici ce n'est plus un problème, mais c'est loin d'être le seul avantage.
En effet, le son produit par ce petit appareil, en association avec une paire de Hype 4, est complètement hors norme.
Déjà la puissance disponible est bien plus grande qu'il n'y paraît, c'est très confortable en fonction des enregistrements.
Mais surtout, la qualité perçue est immense, et ce quel que soit le style de musique écouté.
Branché sur un OnePlus 11 avec l'application USB Audio Player Pro (réechantillonnage activé), ça marche de manière divine.
Le grave s'exprime à merveille, les voix sont parfaitement claires et les aigus présents mais soyeux.
A l'arrivée ce DC07 Pro est un investissement minime vis-à-vis du résultat obtenu.
Je vais quand même tester son grand frère le DC Elite, mais je ne serai pas surpris si le gap n'est pas si important, malgré la différence de prix.
Je peux donc vous le dire, vous pouvez y aller les yeux fermés, vous risquez surtout d'être étonnés.
The DC07Pro is the new version of iBasso's portable DAC/headphone amplifier. This compact device is equipped with four CS43131 chips and a...
