IFI AUDIO GO BAR KENSEI Portable USB DAC Headphone Amplifier
With the Go Bar Kensei, iFi Audio offers its most powerful USB DAC and ultraportable headphone amplifier. With its particularly compact format, it can accompany you on all your travels, providing high quality listening at all times, whether from a smartphone, tablet or computer.
By buying this product you get 44 loyalty points
Reference : 19190
449,00 €tax incl.
374,17 € tax excl.
iFi Audio GO Bar Kensei Portable USB DAC Headphone Amplifier XMOS 32bit 384kHz DSD256 MQA K2HD
iFi Audio GO Bar Kensei : 3/4 view
Go Bar Kensei: An efficient design
The Go Bar Kensei's digital/analog conversion stage uses a 32bit DAC chip from Cirrus Logic, combined with a high-performance 16-core XMOS USB interface. The latter benefits from custom firmware, to deliver exceptional sound quality. This combination also supports high-resolution files, up to PCM 32bit 384kHz, DSD256 and even MQA (Master Quality Authenticated) and K2HD files.
There's also a digital filter to minimize audio artefacts that can alter listening quality, and a GMT (Global Master Timing) clock for extremely low jitter.
Go Bar Kensei: Sound that adapts to your listening
The Go Bar Kensei offers four digital filtering options to adapt its sound reproduction to your tastes and listening equipment:
  • Bit Perfect: No digital filtering, pure audio signal
  • Standard: Light filtering and treatment of pre/post ringing artifacts
  • Minimum Phase: Slow roll-off, minimal pre/post ringing artifacts
  • Gibbs Transient Optimised: Minimal filtering, no pre-ringing artifacts, minimal post-ringing artifacts
To this, the Go Bar Kensei adds two analog processing modes:
  • XBass+: analog low-frequency boost
  • XSpace: soundstage enhancement for greater immersion
Go Bar Kensei : Controls & connectors
The iFi Audio Go Bar Kensei features physical buttons for easy control. You can precisely adjust the volume level and quickly access the various filtering and processing options. In addition, a series of LEDs indicates the sampling rate of the file currently being played, as well as the options activated.
In terms of connectivity, input is via a USB-C port. For output, the Go Bar Kensei provides both a balanced 4.4mm jack and an S-Balanced 3.5mm jack, enabling you to enjoy the performance of a balanced connection with unbalanced headphones.
Go Bar Kensei : Comfortable power output
Despite its small size, the Go Bar Kensei's symmetrical, isolated amplification circuit delivers comfortable power while considerably reducing noise and crosstalk. The circuit uses high-quality discrete components, and particular attention has been paid to the filtered power supply section.
iFi Audio GO Bar Kensei : Without case
iFi Audio GO Bar Kensei : 3.5mm and 4.4mm jack outputs
Go Bar Kensei : IEMatch & Turbo
The Go Bar Kensei also benefits from the integration of two proprietary technologies, enabling it to adapt to the vast majority of headsets on the market:
  • IEMatch: attenuates power output to suit high-sensitivity headphones and earphones. Suppresses background noise and increases the usable volume range
  • Turbo: Increases the gain level by 6dB to suit the most demanding headphones
Product typePortable USB DAC and headphone amplifier
Input1x USB-C
Outputs1x Single-ended Jack 3.5mm (S-Balanced)
1x Balanced Jack 4.4mm
DAC ChipCirrus Logic
USB interfaceXMOS
Native DSD up to DSD256
DXD up to 32bit 384kHz
MQA
K2HD
Output powerSingle-ended : 300mW @ 32Ω, 3.8V @ 600Ω
Balanced : 477mW @ 32Ω, 7.2V @ 600Ω
Output impedance< 1Ω
Signal-to-noise ratio (SNR)Single-ended : 114dBA
Balanced : 132dBA
Dynamic rangeSingle-ended : 108dB(A)
Balanced : 109dB(A)
Total harmonic distortion (THD)Single-ended : ≤0.009% (16Ω 1.27V) @ (20-20KHz)
Balanced : ≤0.0025% (600Ω 2V) @ (20-20KHz)
Frequency response20Hz - 70kHz (-3dB)
Consumption4W max
Dimensions65 x 22 x 13.2mm
Weight65.5g
Package1x iFi Audio GO Bar Kensei
1x Lightning to USB-C cable
1x USB-C to USB-C cable
1x USB-C to USB-A adapter
1x Leather travel case
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipNC
Max sampling rateK2HD
ColorSilver
Le meilleur !
Je possédais le précédent Go Bar et j’avoue être bluffé par cette version Kensei : le son est indéniablement plus délié, plus riche, plus réaliste quel que soit le type d’écouteurs (intra, casque) et surtout le type de musique. Les ingénieurs japonais ont réussi une belle amélioration par rapport à un produit déjà remarquable avec le traitement K2HD qui restaure des harmoniques naturelles et des harmoniques au-delà de 22 kHz, offrant une qualité audio proche du signal d'origine. Bravo !
This review has been posted for iFi Audio GO Bar Kensei Portable USB DAC Headphone Amplifier XMOS 32bit 384kHz DSD256 MQA K2HD
With the Go Bar Kensei, iFi Audio offers its most powerful USB DAC and...
