IFI AUDIO GO LINK Portable DAC Adapter ES9219MQ/Q USB-C to Jack 3.5mm 32bit 384kHz DSD256 MQA
Reference : 17148
59,00 €tax incl.
49,17 € tax excl.
Shipping date: 16-04-2025.
iFi Audio Go Link
iFi Audio Go Link DAC Portable Adaptateur ES9219MQ/Q USB-C vers Jack 3.5mm 32bit 384kHz DSD256 MQA
The iFi Audio Go Link is the perfect accessory for connecting headphones or earphones to a device that does not have a Jack 3.5mm headphone output, such as a recent smartphone. It also allows devices with a headphone output to enjoy better sound thanks to the built-in high-quality DAC and headphone amplifier.
The Go Link consists of a USB-C male input and a Jack 3.5mm headphone output. Each part is clad in a strong and light magnesium alloy body. Between the two, a 6cm flexible cable allows for convenient use while reducing mechanical stress on the connectors and connected devices. In addition, the cable incorporates individually insulated, silver-plated copper conductors, ensuring excellent conductivity for perfect signal transmission.
The core of the Go Link houses a powerful ES9219MQ/Q DAC from ESS Technology, taking advantage of the manufacturer's 32bit HyperStream III architecture.
In addition to this DAC, the Quad DAC+, Time Domain Jitter Eliminator and a dedicated clock circuit allow to reach a very low level of distortion to reveal a clear and dynamic sound. The DRE (Dynamic Range Enhancement) technology allows an adjustment of the analog gain to minimize THD and crosstalk.
Hi-Res certification
The Go Link is Hi-Res Audio certified and supports high-resolution audio streams, up to PCM 32bit 384kHz and DSD256, for rich, detailed and dynamic sound reproduction. It can also decode MQA (Master Quality Authenticated) files for a sound reproduction as close as possible to the original studio recording. An LED indicator allows you to quickly and easily identify the type of stream being played.
Review
"The most important thing to remember about this little iFi GO link is that it's a sure bet for anyone looking to considerably improve the sound quality of a laptop or smartphone for listening with headphones or wired IEMs."
Product typePortable DAC
Input1* USB-C
Output1* S-BAL Jack 3.5mm headphone output
Supported sampling rates and formatsPCM up to 32bit 384kHz
Native DSD up to DSD256
MQA
Output power≥ 1.5V / 70mW @ 32Ω
2V / 14mW @ 300Ω
Output impedance< 0.4Ω
SNR≥ 125dBA (2.05V)
Dynamic range≥ 122dB(A) @ 0dBFS
THD+N< 0.0004% (1.27V @ 32Ω)
Frequency response10Hz - 80kHz (-0.5dB)
ConsumptionAucun signal : ~0.2W
Signal max : ~1W
Dimensions (L*P*H)135*12.6*7.6mm
Cable length6cm
Weight11g
OutputJack 3.5mm
DAC / ADC ChipES9219MQ/Q
Max sampling rate384kHz
Max sampling rateMQA
Max sampling rateDSD256
ColorGray
Excellent for the money, the sound and quality of production are as expected. The only thing is that it drains the phone battery a little more than expected.
This review has been posted for IFI AUDIO GO LINK Portable DAC Adapter ES9219MQ/Q USB-C to Jack 3.5mm 32bit 384kHz DSD256 MQA
