IFI AUDIO HIP DAC 3 Portable DAC Headphone Amplifier
iFi Audio's Hip DAC returns in an improved version, the Hip DAC 3. A practical and efficient DAC and headphone amplifier combo, this new version offers improved design and sound performance. The Hip DAC 3 is equipped with a Burr Brown DAC chip, a 16-core XMOS USB interface and an amplifier stage capable of developing comfortable power.
Reference : 19214
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 16-04-2025.
iFi Audio Hip DAC 3 DAC Portable Balanced DAC Headphone Amplifier Burr Brown XMOS 32bit 384kHz DSD256 MQA
iFi Audio Hip DAC 3: 3/4 view
Two USB-C ports now simplify cable management: one for audio signal transmission, the other for charging. In addition, a switch on the underside activates the brand's iEMatch technology, optimizing use with high-sensitivity headphones and earphones.
On the component side, the circuit features new metal-film capacitors for improved frequency response, as well as an updated version of the GMT circuit, coupled with a new crystal oscillator, further reducing phase noise for pure sound.
iFi Audio Hip DAC 3: Top view
iFi Audio Hip DAC 3: Compact & Elegant
With its sturdy, elegant and compact aluminum case, the Hip DAC 3 slips discreetly into a pocket or bag. It replaces the DAC and amplifier of smartphones, tablets and computers. Simply connect it via USB-C, plug in your favorite headphones and enjoy rich, dynamic sound.
Burr Brown and XMOS logos
iFi Audio Hip DAC V3: Burr Brown DAC and XMOS USB interface
The Hip DAC 3 integrates a digital/analog conversion stage equipped with a Burr Brown chip, for which iFi Audio now benefits from extensive expertise to ensure optimum performance. This is accompanied by a 16-core XMOS USB interface, programmed by iFi Audio to optimize sound quality.
iFi Audio Hip DAC 3: Optimized circuitry, powerful headphone amp
The Hip DAC 3 features a fully balanced circuit that minimizes signal distortion for purer sound. It incorporates high-end components such as an iFi OV custom OPA, a Texas Instruments low-noise power supply IC and a high-quality analog volume potentiometer.
The Hip DAC 3's amplifier stage is capable of delivering 400mW of power at 32Ω (balanced output), making it compatible with a wide range of headphones. What's more, it efficiently powers high-impedance headphones with an output voltage of 6.3V at 600Ω (balanced output).
iFi Audio Hip DAC 3: Use with a smartphone
iFi Audio Hip DAC 3: Bottom view
iFi Audio Hip DAC V3: Particularly efficient technologies
The amplification stage is equipped with a switchable gain, called PowerMatch, to ensure optimum power regardless of the headphones used.
A switch on the underside of the unit activates iEMatch technology, optimizing output for high-sensitivity headphones and earphones. This reduces hiss, improves detail and dynamic range, and also extends the volume control range.
The XBass function, which can be activated or deactivated, enhances bass without altering the midrange, particularly useful for use with open earphones or headphones. It works in analog mode, avoiding DSP alterations.
MQA logo
iFi Audio Hip DAC V3 : High resolution files & MQA
The Hip DAC 3 supports PCM and DXD audio streams up to 32bit 384kHz, as well as DSD up to DSD256. Full MQA decoding is also supported, enabling you to take advantage of this type of file, aimed at providing sound reproduction as close as possible to studio recording. On either side of the volume knob, a pair of LEDs change color according to the file format currently being played.
iFi Audio Hip DAC V3: Perfect versatility
The asynchronous design of the USB interface guarantees jitter-free data transfer. A separate USB-C charging port enables use while charging, preserving a path for the pure audio signal.
The iFi Audio Hip DAC3 provides two outputs, in unbalanced 3.5mm jack and balanced 4.4mm jack formats. The 3.5mm jack output uses the brand's S-Balanced circuitry, minimizing crosstalk and distortion.
The Hip DAC 3's 2200mAh battery provides up to 12h of autonomy, depending on volume and headphone power requirements. A USB-C OTG and USB-A to USB cable are included.
iFi Audio Hip DAC 3: Connection diagram for headphones
iFi Audio Hip DAC 3: Button and connector diagram
1Audio USB-C input
2USB-C 5V charging port
3PowerMatch switch
4XBass switch
5Volume / ON-OFF button
6Balanced Jack 4.4mm headphone output
7Single-ended Jack 3.5mm headphone output
Product typePortable DAC and headphone amplifier
Input1x USB-C
Outputs1x Balanced Jack 4.4mm headphone output
1x Single-ended Jack 3.5mm headphone output
DAC chipBurr Brown
USB interfaceXMOS
DSD up to DSD256
MQA
Output powerBalanced output: 400mW @ 32Ω / 6.3V @ 600Ω
Single-ended output: 280mW @ 32Ω / 3.2V @ 600Ω
Output impedance≤ 1Ω
≤ 4.5Ω with iEMatch enabled
Signal/Noise ratio (SNR)Balanced output: < 109dB(A) @ 0dBFS
Single-ended output: < 103dB(A) @ 0dBFS
Dynamic range (DNR)Balanced output: < 109dB(A)
THD+NBalanced output: < 0.006% (360mW / 2.0V @ 600Ω)
Single-ended output: < 0.01% (100mW / 1.27V @ 16Ω)
Frequency response20Hz - 45kHz (-3dB)
BatteryLiPo 2200mAh
Battery lifetime~ 8h
Consumption< 2W idle
4W max
Power systemCharge via USB-C, BC V1.2 support up to 1000mA
Dimensions102 x 70 x 14mm
Weight135g
Package1x iFi Audio Hip DAC V3
1x USB-C cable
1x USB-C to USB-A cable
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipBurr Brown
Max sampling rate384kHz
Max sampling rateMQA
Max sampling rateDSD256
ColorBrown
IFI AUDIO HIP DAC 3 Portable Balanced DAC Headphone Amplifier Burr Brown XMOS 32bit 384kHz DSD256 MQA
iFi Audio's Hip DAC returns in an improved version, the Hip DAC 3. A practical and efficient DAC and headphone amplifier combo, this new...
