IKKO LOT Adapter DAC Male USB-C to Female Jack 3.5mm 16bit 48kHz
This Ikko Lot adapter and DAC has a male USB-C connector and a female 3.5mm jack. It is ideal for connecting headphones to a smartphone that does not have a 3.5mm jack audio output.
3.0 / 5
Reference : 16862
9,90 €tax incl.
8,25 € tax excl.
Ikko Lot
Ikko Lot Adaptateur DAC USB-C mâle vers Jack 3.5mm femelle 16bit 48kHz
This Ikko Lot adapter and DAC has a male USB-C connector and a female 3.5mm jack. It is ideal for connecting headphones to a smartphone that does not have a 3.5mm jack audio output. The built-in DAC supports PCM audio streams up to 16bit 48kHz. The adapter is also compatible with cables with built-in control buttons.
Product typeDAC and adapter
Connectors1x Male USB-C
1x Female Jack 3.5mm
Supported sampling ratesPCM up to 16bit 48kHz
Connectors body materialAluminum
External sheath materialBraided nylon
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate48kHz
ColorGray
ConnecticMale & Female
ConnectorUSB-C
ConnectorJack 3.5mm
Contacts Plating (Connector)N/A
2 reviews
disappointment
Tested under Windows 10, Lenovo T14. It hums, heats up, and beeps slightly. The factory sound card is better than this.
This review has been posted for IKKO LOT Adapter DAC Male USB-C to Female Jack 3.5mm 16bit 48kHz
tres bon
fonctionne parfaitement ,le son est puissant et net
This Ikko Lot adapter and DAC has a male USB-C connector and a female 3.5mm jack. It is ideal for connecting headphones to a smartphone that does...
