The Moondrop Echo-A is a compact, high-performance USB-C to 3.5mm jack adapter designed to deliver a high-resolution audio experience with ease. It incorporates a DAC/headphone amplifier chip capable of supporting sampling rates up to PCM 32bit 384kHz. Thanks to its plug and play compatibility with many operating systems via the UAC 2.0 protocol, the Echo-A is extremely easy to use. It guarantees clear, precise sound reproduction, with a THD+N of just 0.01% and an SNR of around 100dB. Designed primarily for use with smartphones, it can also answer calls using the OMTP protocol.
Product type | USB-C to 3.5mm jack adapter / DAC |
Connectors | 1x USB-C male 1x Jack 3.5mm female |
Supported sampling rates | PCM up to 32bit 384kHz |
SNR | 100dB (A-WT) |
Dynamic range | 102dB (A-WT) |
THD+N | 0.01% |
Phone calls | OMTP protocol via 3.5mm jack |
OS compatibility | Windows, MAC OS, Android, IOS |
Package | 1x Moondrop Echo-A |
Input | USB |
Output | Jack 3.5mm |
DAC / ADC Chip | NC |
Max sampling rate | 384kHz |
Color | Silver |
Networking | No |
Remote Control | Control app |
