The Moondrop Echo-B is a compact, high-performance USB-C to 4.4mm balanced jack adapter, designed to deliver a high-resolution audio experience with ease. It incorporates a DAC/headphone amplifier chip capable of supporting sampling rates up to PCM 32bit 384kHz. Thanks to its plug and play compatibility with many operating systems via the UAC 2.0 protocol, the Echo-B is extremely easy to use. It guarantees clear, precise sound reproduction, with a THD+N of just 0.001% and an SNR of 117dB. Added to this is the possibility of DSP tuning via the Moondrop app for customized sound rendering.
Product type | Adapter / DAC USB-C to jack 4.4mm |
Connectors | 1x Male USB-C 1x Female balanced Jack 4.4mm |
Supported sampling rates | PCM up to 32bit 384kHz |
SNR | 117dB (A-WT) |
Dynamic range | 120dB (A-WT) |
THD+N | 0.001% |
DSP settings | Via Moondrop app |
OS compatibility | Windows, MAC OS, Android, IOS |
Package | 1x Moondrop Echo-B |
Input | USB |
Output | Jack 4.4mm |
DAC / ADC Chip | NC |
Max sampling rate | 384kHz |
Color | Silver |
Networking | No |
Remote Control | Control app |
