The Questyle CMA 18P is a compact, high-performance portable DAC/headphone amplifier featuring a high-performance AKM AK4493 DAC chip and a XMOS XU316 USB interface, mostly used in sedentary DACs. These chipsets enables the CMA 18P to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. The brand's proprietary CMA amplification technology with SIP CC630/CA630 chips (current-mode amplification) also provides the CMA 18P with considerable output power, up to 5W / 2A peak. A Bluetooth receiver chip also enables it to support high-definition Bluetooth codecs: aptX, aptX HD and LDAC. In terms of interface, the Questyle CMA 18P boasts extensive connectivity with USB-C input, mini-Toslink/jack 3.5mm cmbo and balanced jack 4.4mm inputs, as well as analog jack 3.5/4.4mm outputs and USB ADC output. The whole unit is powered by a 4500mAh battery offering over 10h of autonomy. Coupled with a smartphone, tablet or computer, this little DAC/headphone amplifier is an ideal ally for enjoying your music library or streaming services.
The AKM AK4493 2-channel 32-bit DAC featuring Velvet Sound technology, coupled with a third-generation XMOS XU316 USB interface, supports sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. This combination of chips is usually found in sedentary devices, making the Questyle CMA 18P an ultra-high-performance portable headphone amplifier DAC thanks to its high-end components.
As well as being an efficient DAC, the Questyle CMA 18P can convert an analog signal into a digital one. This feature allows you to rip vinyl records, audiocassettes or your favorite radio programs, for example.
The Questyle CMA 18P features a current-mode amplification (CMA) circuit with SIP CC630/CA630 chips, enabling it to develop considerable power up to 5W / 2A peak. With 1W of power @ 32 ohm on its balanced output, it can drive many of the headphones and IEMs available on the market.
Thanks to its Bluetooth functionality, the Questyle CMA 18P supports reception of high-definition Bluetooth codecs: SBC, AAC, aptX, aptX HD and LDAC. It can therefore guarantee high-quality wireless transmission via a smartphone, for example.
A 4500mAh lithium battery working in conjunction with a powerful power management system enables it to be recharged in 3.5h for an autonomy of over 10h. This power management system prevents overheating and preserves battery life through complete optimization.
Thanks to the Questyle CMA 18P's analog line-level inputs and outputs, it can be completely inserted between a streamer and the rest of your Hi-Fi system, transforming it into a sedentary DAC. This is made possible by using RCA to 3.5mm stereo jack or XLR to 4.4mm balanced stereo jack modulation cables. It can also be used as a Bluetooth receiver at the beginning of your Hi-Fi system, for quick and easy access to streaming services.
1 | ON/OFF button |
2 | Volume control |
3 | Source selection |
4 | Gain adjustment |
5 | NC |
6 | Balanced 4.4mm stereo jack input |
7 | Mini-Toslink/Jack 3.5mm input |
8 | USB-C input/charging port |
9 | Jack 3.5mm output |
10 | Balanced 4.4mm jack output |
Product type | DAC / headphone amplifier |
DAC chip | AKM AK4493 |
Amplification | Current-mode amplification with CC630/CA630 SIP chips |
Inputs | 1x USB-C 1x Balanced 4.4mm stereo jack 1x 3.5mm/Toslink jack |
Outputs | 1x 4.4mm stereo balanced jack (headphones and line) 1x 3.5mm stereo jack (headphones and line) |
Supported sample rates | USB : PCM 32bit 768kHz, DSD DoP256, DSD512 Optical Mini- Toslink (3.5mm jack) : PCM 24bit 192kHz |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, LDAC |
Max. output power | 1W @ 32 ohms (Balanced output) |
THD+N | 0.0003% |
SNR | > 120dB |
Compatibility | MFI certification for IOS, Harmony OS, Android 5.1 and + Windows 10 version 18.3 and + (without driver) MAC OS |
Battery | Lithium 4500mAh |
Charging time | 3.5h |
Autonomy | >10h |
Dimensions | 110 x 70 x 10mm |
Package | 1x Questyle CMA 18P 1x USB-C to USB-C cable 1x Lightning to USB-C cable 1x USB-C to USB-A adapter 1x Toslink to 3.5mm optical jack adapter 1x USB-C to USB-C charging cable |
Input | USB |
Input | Bluetooth |
Input | Jack 4.4mm |
Input | Jack 3.5mm |
Input | Optical Mini-Toslink |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
DAC / ADC Chip | AK4493 |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Class | N/A |
Networking | No |
Remote Control | No |
