SHANLING H7 Portable DAC Headphone Amplifier Black
With the H7, Shanling unveils a portable DAC and headphone amplifier with integrated player, based on high-end components such as an AK4499EX DAC chip accompanied by its AK4191EQ Delta-Sigma modulator. The presence of a latest-generation USB XMOS interface coupled with AKM chips enables the H7 to process signals up to PCM 32bit 768kHz and DSD512. Furthermore, the beautiful AB-class amplification coupled with the various gain settings enable this device to drive even the most demanding headphones, while offering a warm, smooth sound with ample dynamics.
By buying this product you get 82 loyalty points
Reference : 20083
829,00 €tax incl.
690,83 € tax excl.
Shipping date: 16-04-2025.
Shanling H7 Portable DAC AK4499EX AK4191EQ Headphone Amplifier Bluetooth 5.0 XMOS 32bit 768kHz DSD512 Black
Shanling H7 : 3/4 view
Shanling H7: AKM DAC system
The H7 features the new generation of AKM's flagship DAC system. This combo of a Delta-Sigma AK4191EQ modulator and an AK4499EX DAC splits the digital/analog conversion between the two chips to improve overall system performance. This approach, coupled with an XMOS XU316 USB interface, enables signals up to PCM 32bit 768kHz and DSD512 to be processed, while offering a signal-to-noise ratio of 123dB and a harmonic distortion rate of just 0.00006%.
Shanling H7 : DAC chips
Shanling H7 : Amplification chip
Shanling H7: Class AB amplification
The H7's amplifier stage has been developed around a Class AB TPA6120A2 amplifier chip. This is accompanied by Elna Silmic II capacitors to deliver a warm yet soft, deeply organic sound. Furthermore, to ensure broad compatibility with the majority of headphones, the H7 has 3 different gain settings, providing up to 1300mW output power at 32Ω to drive the most demanding headphones.
Shanling H7: Solutions developed by Shanling
The H7 has benefited from special attention to detail in every aspect of its design. Many of the components were developed in-house by Shanling. Starting with the FPGA and the internal clock with dual 45 MHz / 49 MHz low-noise active oscillators, enabling phase noise to be reduced to extremely low levels. Furthermore, the I/V conversion stage based on a pair of ADA4896-2 OPAs features resistors and capacitors specially selected by Shanling to deliver the best possible performance. Finally, the brand has selected an OPA2211 coupled with 100μF capacitors as low-pass filter for extremely low noise and wide bandwidth.
Shanling H7 : I/V conversion
Shanling H7 : In use
Shanling H7: Impressive connectivity
The H7 is equipped with a wide range of connectors to ensure compatibility with the widest possible range of configurations. On the input side, the H7 has a coaxial input that can also receive an optical signal, a USB-C input, and a micro SD port.
On the output side, furthermore to a line output, the H7 has 3 headphone outputs in Jack 3.5mm, Jack 4.4mm and Jack 6.35mm, allowing you to connect to them, whatever your headphone connection.
Shanling H7: Bluetooth 5.0
The Shanling H7 can be transformed into a high-quality Bluetooth DAC/headphone amplifier. It supports the high-resolution Bluetooth codecs LDAC (Android) and AAC (IOS).
Shanling H7 : Battery
Shanling H7: 6800mAh battery
To take you wherever you go, the H7 is equipped with two 18650 batteries for a total capacity of 6800mAh, plus a dedicated power management unit. This gives it an autonomy of 10h of continuous listening on Single-ended and 8h of continuous listening on Balanced.
Shanling H7: Eddict Player application
To easily browse the files on the micro SD card inserted in the H7, or simply modify its settings such as UAC 1.0 activation, you can use the Eddict Player application available on Android and iOS, allowing you to enjoy lossless files without the need for cables or a Bluetooth connection.
Application Eddict Player
Shanling H7: LED indicator
The H7's LED indicators let you read various information at a glance, such as the sampling rate being played back or the state of charge.
Charge indicator
  • Red: charging
  • Off: charging time
MQA indicator
  • Blue: MQA stream
  • Off: non MQA stream
Sampling rate indicator
  • Blue: 44.1 / 48kHz
  • Yellow: 88.2 / 96 / 176.4 / 192kHz
  • Purple: 352 / 384 / 705 / 768kHz
  • Green: DSD64 / DSD128 / DSD256 / DSD512
MQA playback indicator
  • Blue: MQA Studio
  • Green: MQA
  • Purple: MQA Rendering
Product typePortable DAC / Headphone amplifier
DAC chipAK4499EX + AK4191EQ
USB interfaceXMOS XU316
Amplification chipTPA6120A2
Inputs1x USB-C
1x Slot micro-SD (2To max) (SD card not included)
1x Input Coaxial/ Optique
Bluetooth 5.0
Outputs1x Jack 3.5mm
1x Jack 4.4mm
1x Jack 6.35mm
1x RCA line output
Supported sample ratesPCM 32bit 768kHz
DSD512
Supported Bluetooth codecsSBC / AAC / LDAC
Audio FormatsDSD (".ISO", ".DSF", ".DFF")
MQA, ISO DXD, APE, FLAC, WAV, AIFF, DTS, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8, OPUS
Digital filters6 built-in filters
Gain adjustment3 gain levels
Screen1.44"
Fast chargeQualcomm QC3.0
RCA line Output measurements
Output level2.4Vrms
Frequency response20Hz - 40kHz (-0.2dB)
Total harmonic distortion more noise (THD+N)0.0006%
Dynamic range121dB
Signal-to-noise ratio (SNR)121dB
Single-ended output measurements
Output powerLow gain : 28mW @32Ω
Medium gain : 112mW @32Ω
High gain : 450mW @32Ω
Total harmonic distortion more noise (THD+N)0.0009%
Channel separation75dB @32Ω
Dynamic range121dB
Noise>113dB(<1.5μV) (Faible Gain)
Output impedance<1Ω
Balanced output measurements
Output powerLow gain : 87mW @32Ω
Medium gain : 348mW @32Ω
High gain : 1300mW @32Ω
Total harmonic distortion more noise (THD+N)0.0007%
Channel separation115dB @32Ω
Dynamic range123dB
Signal-to-noise ratio (SNR)123dB
Noise>111dB(<1.5μV) (Faible Gain)
Output impedance<1Ω
Power supply voltage3,6 V - 12 V
Weight350g
Dimensions142 x 85 x 25mm
Package1x Shanling H7
1x USB-A to USB-C cable
1x USB-C to USB-C cable
1x Jack 3.5mm to RCA coaxial cable
1x Storage bag
InputMini Toslink 3.5mm
InputMicro SD
OutputJack 6.35mm
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipAK4191
DAC / ADC ChipAK4499EX
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ClassClass A / AB
SHANLING H7 Portable DAC AK4499EX AK4191EQ Headphone Amplifier Bluetooth 5.0 XMOS 32bit 768kHz DSD512 Black
With the H7, Shanling unveils a portable DAC and headphone amplifier with integrated player, based on high-end components such as an AK4499EX DAC...
