SHANLING UA1 Pro Adapter DAC USB-C ES9219C 32bit 384kHz DSD256 80mW 32 Ohm Black
Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or you simply want to improve the very average audio output of a standard consumer phone, the Shanling UA1 Pro is a transportable and affordable solution for playing your high resolution audio files anywhere without carrying  more than necessary.
Reference : 15576
49,90 €tax incl.
41,58 € tax excl.
Shanling UA 1 Pro
Portable DAC USB-C ES9218P 384kHz DSD256
Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or you simply want to improve the very average audio output of a standard consumer phone, the Shanling UA1 pro is a transportable and affordable solution for playing your high resolution audio files anywhere without carrying  more than necessary.
DAC ES9219C
Although very compact, the Shanling UA 1 Pro embeds a high-quality audio circuit built around an ESS ES9219C chip. This famous component for High Fidelity applications incorporates both digital to analog conversion capabilities as well as headphone amplification capabilities. This second version hence offers better performance in terms of harmonic distortion.
On the DAC side, the UA1 is capable of playing high resolution audio files up to 384kHz / 32bit and even DSD files up to DSD256. The output stage is for its part capable of developing up to 80mW of power at 32 Ohm with a minimal noise level, which represents an incomparable performance gain in comparison with the traditional audio outputs of general public portable multimedia devices.
USB-A adapter
The UA1Pro portable headphone converter and headphone amplifier from Shanling comes with a USB-C female to USB-A male adapter. The latter will be particularly useful for using all the qualities and audio capabilities of the UA 1 pro with a laptop or even a PC without a satisfactory sound card (relying only on the limited audio capabilities of the motherboard).
Completely optimized for mobile use, the circuit is designed to maximize the power available for the amplified output while limiting the load on the battery of the source device. This is a suitable solution for extended listening sessions, even on devices with limited battery.
Shielded cable
The integrated cable has high purity & high section copper conductors ensuring excellent conductivity for your audio streams. It is securely protected by a robust sheath and has cotton / silver shield specially designed to limit the capture of high-frequency waves, such as those specifically present near a smartphone.
TypePortable DAc
Inputs1x USB-C
Outputs1x Jack Stereo 3.5mm single ended
Output power80mW @ 32Ω (1.6V)
Frequency response20Hz - 50kHz (-0.5dB)
THD+N0.0006% @32Ω (A)
Dynamics119 dB @32Ω (A)
SNR119dB @32Ω (A)
Crosstalk77dB @32Ω
Output mpedance≤0.5Ω
Dimensions39x15x9 mm (corps)
77mm (cable)
Weight8.3g
Package COntents
UA1 Prox1
USB-C Female to USB-A mâle adapterx1
Manualx1
OutputJack 3.5mm
DAC / ADC ChipES9219C
Max sampling rateDSD256
Max sampling rate384kHz
Géant !!!!!!!!!!!!
Extrêmement satisfait
Utilisant avec mon Mi 10 il change radicalement la qualité du son
Même avec mon autre dac plus cher je trouve celui ci nettement meilleur.
This review has been posted for SHANLING UA1 Pro Adapter DAC USB-C ES9219C 32bit 384kHz DSD256 80mW 32 Ohm Black
Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or...
