SHANLING UA2 Balanced DAC USB-C ES9038Q2M 768Khz DSD512
Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or you simply want to improve the very average audio output of a standard consumer phone, the Shanling UA2 is a transportable and affordable solution for playing your high resolution audio files anywhere without carrying  more than necessary.
Reference : 15165
85,00 €tax incl.
70,83 € tax excl.
This product has been replaced by the new version, the SHANLING UA2 PLUS Portable Balanced DAC USB-C ES9038Q2M.
Shanling UA 2
DAC portable USB-C ES9038Q2M Balanced 768kHz DSD512
This second version of the UA series is equipped with increased decoding capacities with an independent amplification stage also offering a balanced output.
High Fidelity Audio circuit
Although very compact, the Shanling UA 2 embeds a powerful audio circuit built around an ESS ES9038Q2M chip, a reference component for High Fidelity applications incorporating digital to analog conversion capabilities.
On the DAC side, the UA2 is capable of playing high resolution audio files up to 768kHz / 32bit and even native DSD up to DSD512.
The output stage is built around an RT6838 chip capable of developing a power up to 125mW under 32 Ohm with a minimal noise level, which represents an incomparable performance gain in comparison with the traditional audio outputs of general public portable multimedia devices.
USB-A adapter
The UA2 portable headphone converter and headphone amplifier from Shanling comes with a USB-C female to USB-A male adapter. The latter will be particularly useful for using all the qualities and audio capabilities of the UA 2 with a laptop or even a PC tower without a satisfactory sound card (relying only on the limited audio capabilities of the motherboard).
Completely optimized for mobile use, the circuit is designed to maximize the power available for the amplified output while limiting the load on the battery of the source device. This is a suitable solution for extended listening sessions, even on devices with limited battery.
Shielded cable
The integrated cable has high purity & high section copper conductors ensuring excellent conductivity for your audio streams. It is securely protected by a robust sheath and has cotton / silver shield specially designed to limit the capture of high-frequency waves, such as those specifically present near a smartphone.
TypePortable DAC
Inputs1x USB-C
Outputs1x Jack 3.5mm Stereo single-ended
1x Jack 2.5mm Stereo Balanced
Output power195mW @ 32Ω (Balanced)
125mW
Frequency response20Hz - 50kHz (-0.5dB)
THD+N0.0008% @32Ω (A)
Dynamic range
SNR
116dB @32Ω (A) (Balanced)
Crosstalk
109dB @32Ω (Balanced)
76dB @32Ω (single-ended)
Output impedance1.6 Ohm (Balanced)
0.8 Ohm (single-ended)
Dimensions54x18x9 mm (corps)
77mm (câble)
Weight12.6g
package
UA2x1
Adaptateur USB-C Femelle vers USB-A Mâlex1
Manuelx1
OutputJack 3.5mm
OutputJack 2.5mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
3 reviews
DAC au top
Un petit DAC fort joli, très pratique et polyvalent mais grand par le son. Fonctionne parfaitement sur MacOs Monterey (pas évident), le son au casque (je ne fais pas la liste) et avec les HP (Iloud Micro Monitor) est parfait, bon rendu à fort volume comme à bas volume.
Parfait pour une utilisation Hifi ou professionnelle (studio) car très détaillé et toutes les fréquences passent à merveille. Je recommande vivement.
Je n'ai pas testé la sortie symétrique ni sur Iphone mais je ne pense que cela soit moins bon.
This review has been posted for SHANLING UA2 Balanced DAC USB-C ES9038Q2M 768Khz DSD512
Shainling UA2 dac
Dispositivo eccezionale pilota a 8/10 su uscita da 3.5 sbilanciata le mie amate e vecchie sennheiser hd 424x da 2000 ohm !!!! mentre le hidiz MS1 in ear e shure ec2 vengono pilotate con facilità a 2/10 de volume del samsung S10, il suono con file 24/192 è stupendo
...spedizione audiophonics velocissima.....ordinato lunedì mattino, arrivato in Italia giovedì mattino
packaging perfetto
Super rapport qualité prix
Etant content du dac sabre 9038 de salon je me suis dit que cela devait être bien en version nomade : utilisé entre un P30 Huawei (Tidal) et un casque Hifiman, le résultat me plait puisque pour le moment je n'ai pas eu à utiliser un ampli de casque que je possède tant la sortie me parait suffisante. Je ne suis pas un expert, le son me parait aussi bon voire meilleur que sur mon lecteur Fiio M7 (ES9018).
Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or...
