SHANLING UP nomad DAC MFI Headphone Amplifier ES9018K2M MAX97220A
4.5 / 5
Reference : 11571
129,00 €tax incl.
107,50 € tax excl.
es9018k2m shanling UPThe new SHANLING UP portable USB DAC will be the ideal companion for nomadic listening compatible with OTG Android, Laptop PC, iOS thanks to its compatibility MFI.
Whether on tablets, Android smartphones, iOS smartphones or iPads, the SHANLING UP warranty High Fidelity and High Definition up to 32Bit / 192Khz.
The headphone amplifier chip is the MAX97220A low consumption and the DAC, a ESS SABRE ES9018K2M. It thus opens on Smartphone, high definition channels with nomadic version with native decoding 64 and 128. The selection of gain High-and-low allows the use of a wide range of headphones nomads low and medium impedance.
WARNING ! Be sure to check the OTG compatibility of your terminal!
Shanling UP review by Qobuz
" This DAC Shanling Up is a very elegant device offering a sound restitution knowing how to show a great refinement as well as to let the most fished music express itself with force. "
Test Qobuz
  • Signal Noise Ratio: 108dB
  • Sampling rate: 32bit / 192khZ Output Level 1.45V 32 Ohm
  • DSD64 and DSD128 native
  • Frequency response: 20hz to 20khz Headphone output power: 65mW @ 32 ohm
  • Total harmonic distortion: 0.0004% (600mV @ 32ohm)
  • Gain selectable headphone output <strong>High and Low
Connectors:
  • Input Micro USB TYPE C </ Li>
  • Analog Output 3.5mm
Compatibilities: </ Strong>
  • Windows XP
  • Windows 7, 8, 10 (32 / 64bit)
  • Mac OS X
  • iOS 10.7Android
    Weight & dimensions:
    • Weight: 13g
    • Dimensions: 62x24x7.2mm
    • Black color
Accessories :
  • Type C Lightning, Micro USB (OTG) TYPE-C, USB A Type C, Type C OTG .
Color
  • Black
Input
  • USB
Output
  • Jack 3.5mm
Remote Control
  • No
2 reviews
Marche très bien sur Iphone, mais pb pas résolu sur Mac
Ce petit Dac marche très bien avec mon iPhone que ce soit avec l'appli iAudioGate ( Korg) ou Hiby
Par contre impossible de le faire fonctionner avec mon Macbook Pro que ce soit avec iTunes ou avec Audirvana.... Là je ne sais comment faire ...
Le mode d'emploi est rachitique ( et uniquement en anglais ou japonais, bien qu'il me semble qu'il soit obligatoire de fournir une notice en français...)
This review has been posted for SHANLING UP nomad DAC MFI Headphone Amplifier ES9018K2M MAX97220A
Petit et efficace
Après un bon rodage et une écoute sur ordinateur avec foobar indexé avec la sortie Kernel Streaming, le rendu est très bon : du détail, de la subtilité, du tempo dans les notes des fréquences basses à hautes et du liant entre chaque registre. Avec la sortie Asio, ce dernier critère était vraiment en retrait : son décortiqué.
Note : jamais utilisé sur une tablette – téléphone car ce n’est pas ma priorité.
