SMSL iDEA USB DAC Headphone Amplifier XMOS U208 ES9018Q2C DSD512 Red
The SMSL iDEA is an extremely compact and powerful USB DAC and headphone amplifier. It will be the perfect companion for OTG and iOS compatible mobile listening
Reference : 13794
89,00 €tax incl.
74,17 € tax excl.
SMSL iDEA
DAC USB Amplificateur Casque XMOS U208 ES9018Q2C DSD512 Rouge
SMSL iDEA DAC USB Amplificateur Casque XMOS U208 ES9018Q2C DSD512 Rouge
The SMSL iDEA is an extremely compact and powerful USB DAC and headphone amplifier. It will be the perfect companion for OTG and iOS compatible mobile listening. Whether on a tablet, Android smartphone, iOS smartphone or iPad, the iDEA SMSL guarantees high fidelity and high definition with sampling rates up to 32bit 384kHz in PCM and DSD512, thanks to the ES9018Q2C conversion chip.
The headphone amplifier is directly integrated into this ES9018Q2C, DAC conversion chip designed by ESS specifically for mobile and portable applications. It accepts headphones with an impedance between 300Ω and 16Ω. The Micro USB input is directly linked to an XMOS XCore U208 interface, a real strength to ensure high transmission quality while also supporting very high sampling rates, in accordance with the performance of the conversion chip.
The iDEA SMSL is Plug & Play and therefore does not require any driver to operate, except when used in USB DAC mode with a Windows computer. In the latter case, you will need to download the corresponding XMOS driver available in the Download tab of this product sheet.
Be sure to check the OTG compatibility of your reading device (smartphone, tablet...).
SMSL iDEA review by Audio Science Review
" The SMSL iDEA is a very well engineered DAC and headphone amp with very low noise floor and ample power to drive what normally would require desktop amplifier. "
Test du SMSL iDEA par Audio Science Review
Product typeUSB DAC / Headphone amplifier
DAC ChipES9018Q2C
USB InterfaceXMOS XCore200 XU208
Input1x Micro USB
Output1x Jack 3.5mm
THD+N0.0011%
SNR108dB
Dynamic range121dB
Headphone impedance range16Ω - 300Ω
Headphone amplifier output power35.8mW @ 32Ω
31.6mW @ 64Ω
Supported sampling ratesPCM up to 32bit 384kHe
DSD up to DSD512
Integrated power supplyUltra low noise with LDO
CompatibilityActive speaker / amplifier
Windows (driver needed)
Mac OS and iOS (native)
Android 4.0 or most recent
Weight9.5g
Dimensions60 x 16 x 6mm
ColorRed
Housing materialAluminium
Package1x SMSL iDEA
1x Male USB-A to Male Micro USB
1x Male Micro USB to Male Micro USB
1x Male USB-C to Male Micro USB
OutputJack 3.5mm
ColorRed
ColorOther
Download
The SMSL iDEA is an extremely compact and powerful USB DAC and headphone amplifier. It will be the perfect companion for OTG and iOS compatible...
