You can now find the new model of the SMSL brand:
The iDol SMSL is the portable DAC, ideal companion for listening OTG compatible. Whether it is on iPad, tablets, Android 4.0 smartphones, IOS smartphones, SMSL Idol warranty High Fidelity in High Definition 24Bit 96Khz asynchronous.
A superb DAC USB asynchronous portable DAC in black and elegant silver finish with effective volume button, easy to use.
The DAC TI PCM5122 chip and the TAS1020B USB chips as well as the 2 low Jitter clocks guarantee a real asynchronous mode. The SPDIF transmission is done via the CS8406 chip.
In addition to its dual operation with 3.5mm headphone jack and Mini Toslink optical, the SMSL iDol is an excellent USB interface with low jitter allowing the use of your mobile source on a high fidelity DAC (smartphones, tablets, portable laptops) .
Test, SMSOL test IDOL which received the Qobuzissime prize
Technical characteristics :
Chips and chips used:
Compatibility:
Weight and package, supplied accessories:
Playback on Android 4.0 is done with compatible playback software. The Audiophonics team advises you HIBY music on Google Play.
[Img-15727-left-thickbox_default]
[Img-15728-Left-thickbox_default]
