SMSL iDol+ USB OTG DAC Headphone Amplifier Android iOS MAX97220A Silver
Reference : 11990
39,90 €tax incl.
33,25 € tax excl.
Here is the iDol +, the new portable USB DAC from SMSL, following the success of their iDol . It will be your ideal companion for a listening nomad compatible OTG or iOS . Whether on tablets, Android smartphones, iOS smartphones or iPads, the SMSL iDol + High Fidelity Guarantee and High Definition up to 24Bit / 96Khz or 16Bit / 192kHz .
The headphone amplifier chip is the MAX97220A and the USB VT1620A chips. The latter uses an ultra low power (0.1W) technology, which allows it to be powered and used by any mobile device.
This iDol + SMSL is Plug & Play , it does not require any driver, just plug it in to use it. It also acts as an excellent USB interface allowing the use of your mobile source on a High Fidelity DAC (smartphones, tablets, portable laptops).
WARNING ! Be sure to check the OTG compatibility of your terminal!
The use of USB DACsOTG requires a compatible application such as Hiby Music: <a style = "font-size: 14px;" href = "https://play.google.com/store/apps/details?id=com.hiby.music&hl=en" target = "_ blank">Download Hiby Musique
SMSL Idol+ review by Qobuz
" ... he did not disappoint us with his sound performances and even showed better reading skills than those announced. Maybe it was worth it to break your head! "
Test Qobuz
Technical Features :
  • THD + N: 0.025%
  • Power of 64mW at 64Ohm (@ 1% THD + N)
  • Noise Ratio: 85dB
  • Dynamic range: 97dB
  • Sampling rate: 24bit / 96kHz or 16bit / 192kHzInput Micro USB </ Li>
  • Analog Output 3.5mm
Compatibilities :
  • Windows
  • Mac OS and iOS
  • Android 4.0 and newer
Weight and package, accessories:
  • Weight: 11g
  • Dimensions: 55x21x8mm
  • Silver color
  • Comes with a Micro USB to USB-A cable Comes with micro USB to micro USB OTG cable Delivered with small black carrying pouch </ Li>
InputMicro SD
OutputJack 3.5mm
